- Oct 7, 2019
- Metairie, LA
- Website
- www.oraclelights.com
- 2019 Jeep Wrangler JL
- Occupation
- Automotive LED Manufacturing
Looking to upgrade to LED bulbs? This post has all the info!
Check out these videos our team put together comparing other bulbs against ours!Oracle Lighting offers three lines of LED conversion bulbs for headlights and fog lights. As a market leader with over 20 years of expertise, we rate our bulbs using the average lumen output based on the best performance scenario, while other manufacturers rate theirs on max lumen output that’s just theoretical. Our bulbs outperform with quality materials and precise engineering for the best results possible. All of our bulbs are plug-and-play with crystal-clear 6000K light output and a limited time warranty.
S3 Bulbs (Most Budget Friendly)
Let’s start by looking at our S3 bulbs. These pack a punch with an average 3200 Lumens of Crystal Clear 6000K light output. The electronic components of the S3 are housed in a sealed waterproof heat-sink design, eliminating the need for external drivers and cooling fans. These use a CSP LED chip design for high-intensity volume per unit with less heat value resulting in industry-leading Luminous Efficacy. This new low-profile design reduces common bulb fitment issues for an easy Plug & Play DIY installation. Starting at $69.95 and output 1.65x brighter than stock, you’ll get a great bang-for-your-buck on a great quality bulb.
V-Series (Best Overall Performance)
Our V-Series bulbs offer even more advanced technology with an average 3600 Lumens in a color temperature of 6000K. Featuring fcCSP Flip-Chip Scale LED packaging, you’ll get enhanced electrical performance over standard wirebond technology. The class-leading 6-32V voltage protection will allow these bulbs to be used in Daytime Running Light Applications without common flicker issues. This also makes it perfect for vehicle owners in Canada so you can ensure a compliant DRL function. The V-Series bulbs feature our SmartDrive™ Active Thermal Regulation (ATR) temperature management with an integrated constant current linear LED driver inside the bulb to protect the LEDs and the bulb components. All of this results in an ultra-luminous and efficient light output that’s 2.65x brighter than stock with superior durability and reliability starting at $119.95.
4000+ Lumen (Brightest Output)
Our premium bulb line, the 4000+ Lumen series, are high-output LED Headlight bulbs that create an average of 4,000 Lm blanket of light for the driver to increase safety and nighttime visibility. Philips Luxeon ZES chips allow for the increased output while still drawing less than half the power of the factory headlight bulb. These smaller chips also have excellent heat dissipation characteristics, making them extremely reliable even in harsh environments. The new adjustable heat sink makes fitment issues a thing of the past since it is removable to reverse install or to mount outside the headlight back-cap for added adaptability. Also comparable to the once-popular HID bulbs, these feature the latest LED technology that provides output that are 3.18x brighter than stock.
Watch our comparasion video below and pick your bulbs here! (Psst, use code forum10 for an exclusive discount.)
