Error code P219A
long2jump
San tan
2019 Jeep Wrangler Rubicon Unlimited
I am not a mechanic, just a DIYer trying to save some money. I have a 2019 Unlimited Rubicon. Received the P219A code yesterday. Air/Fuel imbalance. Changed the air filter, reset the code and it returned with 10 miles. O2 sensor voltage is between .1 and 1 volt. Which I found to be normal. The scanner has a test function for it and it said it passed. Noticed the fuel pressure is between 75-80psi and the fuel rail pressure is 1100-1500psi, this is at idle. Is that the normal range? Trying to figure this code out.
Jeep Wrangler JL Error code P219A 1000001383
Jeep Wrangler JL Error code P219A 1000001382
Jeep Wrangler JL Error code P219A 1000001381
Jeep Wrangler JL Error code P219A 1000001380
azjl#3
North AZ
this sounds like an issue those years had with faulty O2 or some programming issue.
