Drl wire in fender?
Grayhound
Michigan
Jlurd
I have halo headlights that I have wired to a fuse trap and they work fine. I would rather wire them through the fender and have control of them through the DRL and you connect. I know I have seen some things on here before but I’m not finding the article that clearly states on a 21 Rubicon what wires in the passenger side fender connector power what and how would I wire the halos for DRL off the fender clip?
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
I think it's a white with brown stripe in the harness that feeds the fender lights. You can pull the inner fender to get good access to the wiring.
Grayhound
Grayhound
Michigan
Jlurd
Thanks for the reply, I should have updated.
i pulled the fender and got out my multimeter and found that when looking at the connector the far left is ground, next to the right is drl day, and the 3rd is drl night.
so I made a harness with a resistor diode and spliced in to have all the wiring I needed.
Now I have halo both day and night without a fuse tap, and I have full control through u connect settings!
Grayhound
Grayhound
Michigan
Jlurd
I recently installed some LEDs from factory halogen. I don't think I have DRL from factory so I attempted to wire the DRL connection conductor to the wht/Bn(drk rd?) On my side lamps. My DRL run only when my lights are on and all the way. If I leave lights on auto, everything stays off since it's day light. Should I just tap the #52 fuse to my DRL wire on the LEDs to get what I'm looking for?
What happens when you turn on just your parking lights?
20-Willys
New England
2020 JLU Willys
When I start the Jeep the halos come on. When I turn on the the parking lights the other driving lights and fogs if selected will come on. My Jeep did not come with LED's. I converted all of the lights to LED however (not just bulbs).
