Ja87sm
Hello,
I purchased a set of led headlights on ebay last year. The driver side arrived damaged. I ended up installing them anyway with some creativity to get the beam straight as possible.
I have since purchased a replacement headlight.
If you tilt them the projector assembly rattles. But the lense isn’t cracked or chipped up. Maybe good for a lense transplant or repair if you want to disassemble and fix it. Or good for parts.
I was able to use a big washer and install with the upper alignment tab through a screw hole… if you look at the picture on the Jeep you’ll notice.
-bottom tab broken
-upper tab cracked
-hole in back
100 shipped.
-bottom tab broken
-upper tab cracked
-hole in back
100 shipped.
