need help determining if my 2015 hard rock has mopar lift installed
tshootertech
chris
durham nc
2015 rubicon hard rock
just bought this 2015 hard rock and it has fox 2.0 shocks and stabilizer installed with 35x12.50/17 tires. i think it has not been lifted because the spring length is stock. any way to tell if it does have a mopar factory lift?
word302
Oregon
JLU
I think you'd have better luck in a JK forum.
Carlton
Chicago
Jeeps lots of jeeps
This forum is specific to the 2018.5 and beyond Wrangler JL.
A 2015 is the previous model which is called a JK. I've built many JKs so I can try to help you out.
Your jeep most likely has a lift. 35s do not fit on a JK without a lift. The tires would be very close to the fender flares.
Does the jeep have an aftermarket front drive shaft? The mopar kit came with one. However, it may not be a mopar kit.
My suggestion:
Take the following pictures and post:
1. Part numbers on springs
2. Close up of the shocks
3. Front drive shaft
4. Rear track bar bracket
5. Jeep from the side
It can be confirmed based on this information.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
I know this is the wrong forum, but the Mopar lift for the JK comes with a different style front driveshaft and cam bolts that would differentiate it from most other kits.
