dmoney
- Derek
- Jun 21, 2018
- Central CA
- 18JLUR
I started outfitting Wranglers used for high country and ranch security applications back in 2010. It was pretty simple back when lighting controls were based mainly on relays and switches. Now days, oof. One of the key features my clients like is the ability to “black out” their vehicles when working security on a high ridge, or when they would otherwise be highly visible, etc.
So I’ve been toying with a device I purchased called a Canny 7.2 Duo. Basically, it’s a device that you can connect to the bus and transmit or receive messages to control vehicle functions. For example, sending something like 291 00 46 2B 00 00 28 00 00 would turn the parking lights off.
It can also be used as a CANBUS gateway, which is what I’m working on. Say I have the device connected to the Jeep and to my laptop, and I issue the command to kill the parking lights. They go off, but come right back on because the parking light switch is on and the BCM sees the command coming at a fairly quick rate. That’s where the gateway comes in to play. I have the device sitting between the bus connection to the BCM. During normal conditions, it simply passes messages from the bus to the BCM as normal. However, when I activate a preset voltage or ground input on the gateway module, a program starts running and it will filter out predetermined messages from the vehicle to the BCM. For example, if the Jeep were operating normally with the parking lights on, that means the BCM is receiving a binary message several times a second on the canbus to keep them on. If the driver were to flip a switch connected to the gateway, the gateway would see that binary command on its way to the BCM, filter it out, and in turn, begin issuing the command to turn the parking lights off a few times a second. Pretty neat stuff that can be accomplished without using what used to take 50 feet of wire, relays, tape, enclosures, etc.
What I’d love to find is some sort of documentation on Jeep’s canbus protocol/message format, etc. Currently, it takes a TON of time and effort sifting through thousands of codes, watching for minute changes to determine what does what. Just curious if anyone has ever gotten their hands on something like that?
