Sold: Colorado Break pad wear
Pcherron
Phillip
Wrangler
The picture is the driver's front outside pad.
The break pad on the left side against the caliper is at 3mm. Going deeper away from the camera half way down the pad it is fully intact. It is only wearing closest to the tire and not closer to the axle. The bottom portion that isn't wearing is cracked in the middle. The right break pad looks the same without the crack. The rotors are pristine and measured evenly. These are all the original parts. Is this a normal wear pattern for break pads? Do they need to be changed? Can I use the same rotors?
Jeep jl sahara 2020
66k
Jeep Wrangler JL Break pad wear 20240118_114043
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Yeah, are these for sale? Also, you've listed it specific to Colorado. If you really want traffic, ask to have this moved. Also, they are "brakes".
Pcherron
Pcherron
Phillip
Wrangler
XxsullyxX123
Somers, NY
2020 JLU Rubicon Recon, 2020 Honda Pilot Touring
It says it's listed as wheels tires and brakes. It made me choose a location...colorado.
its listed as wheels tires and brakes.....for sale....look above the FS section for normal discussion threads
