Body Mounted vs Frame Mounted sliders
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
Which style provides better protection on the rocks?
bolt-on or weld-on, does it make a difference?
I’m running LOD Destroyers on my ’19 JLUR which I had to cut to clear the rockers.
Looking for a set for my ’22 JLUR.
What’s everyone’s experience?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Just by looking at what it's attached to, it's pretty clear the body mount will be weaker. There is normally some clearance given up as a trade off as the frame is lower than the body.
I think the strength is the winner, especially since you are not only protecting against rocks vertically, you want the sliders to protect the bottom of the door when you contact a rock from the side.
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
Look at White Knuckle Off-road. I have their sliders. They are bolt on. You do have to drill 2 holes in the frame for maximum protection. You can weld them if you really want to. You can see videos of them lifting the vehicle with just them. I used them in Moab, and they saved my rockers numerous times. Highly recommend. Oh, and you don't have to remove a single body mount bolt to install them. Also, you can order them in a 45 or 90 degree if you want to use them as a step. Here is the link to the website. https://white-knuckleoffroad.com
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
The JL employs a high strength steel frame. It is thinner than on previous Wranglers so I would recommend sliders that attach high and low rather than in the center of the frame.
I don’t think the frame is heat treated so welded or bolted is a matter of personal preference and ability.
Body mounted are best for multi-purpose rigs, lighter and higher clearance but not up to heavy hits.
XtremeRetard
Richard
Rocky Mountains
JLURXR
My stock rubi body mounted rails pressed into the body from impacts creasing it in the middle. So they are not ideal. Though that being said they took some decent whacks and it's only a light crease.
I now have bolt on frame mount rough county sliders
David P.
Durham NC
2021 JLUR
I have VKS Informant sliders that are welded to the frame. Super strong and hard to beat IMO.
Terpsmandan
Penn Yan
I like my LOD signature series. Bolts onto the frame and is also a step.
sherpaJL
sherpaJL
Keystone State
