Bluetooth Phone Call Problem
Jeremyhogsed
Jeremy
Hiawassee, ga
2019 Jeep Wrangler Sahara
I have a 2019 Jeep Wrangler Sahara without the alpine system. My Jeep came with the 7 inch touch screen. I recently just did a complete audio system upgrade. I used the audio control lc7i along with metro t harness to make plug and play. I replaced speakers with infinity reference and amplified them with pioneer 400w micro amp. I put resistors on all four inputs so that I connect would still recognize them. I am running Rockford Fosgate 10 inch sub and amp. Everything works great even the Bluetooth music. The problem I am having is that when making a blue tooth phone call it is so muffled on my end I can barely hear who I am talking to. The person on the other end can hear me just fine. I have volume on radio and and phone turned all the way up. I have deleted phone and reconnected and also done a uconnect reboot and nothing helps.
californiajeeping
JLUR
How did you accomplish the uConnect reboot? Have you tried removing and reinserting the fuse to the audio system? Many of us have found that over 50% of the fuses and relays were loose, causing odd electronic related issues.
Jeremyhogsed
Jeremy
Hiawassee, ga
I haven’t but will try that. I did the reboot by turning jeep to run and holding down voice command button and green call button together at same time for 30 seconds then turning jeep off waiting for uconnect screen to go black open door then close it and start vehicle
