simpleJL
- Kyle
- Nov 29, 2017
- East Bay, CA
- '18 JLUR
A few raw videos with no fancy music.
30 inches is just about to the bottom slots of the grill.Damm, very impressive. I think I read 30 inches is the depth thru water, at what point will the Jeep bog down, when the water is hood height?
Did you drain the axles after or do anything to reroute the air breathers?30 inches is just about to the bottom slots of the grill.
And that's what Jeep advertises of course Liability would be their limit. Realistically it'll go deeper. Intake is at the top of of the engine bay.
If you keep it slow it'll pull through just fine.
You'll kill the engine when you suck in water through the intake. Engine will suffocate.
That's a negative. I'll do some more research on this though.Did you drain the axles after or do anything to reroute the air breathers?
Found a video that showed the rear breather tube - it is located pretty dang high. I will have to take a look underneath and see how high up they are.Did you drain the axles after or do anything to reroute the air breathers?
Good to know let me know what you find I haven't done much water fording yet...also enjoy your JL you've waited long enough for 3+ people on hereFound a video that showed the rear breather tube - it is located pretty dang high. I will have to take a look underneath and see how high up they are.
They are Vision Nemesis wheels.What wheels are those? They look great!
17x9 with a 4.5" backspace.What size are they? Are you going with Mopar beadlocks?
