Auxiliary battery help.
Waynev01
Wayne
2020 jeep wrangler jl Sahara unlimited
I had to recently replace my battery on my 2020 jeep wrangler Sahara unlimited. I know I needed to replace my Aux battery. I saw a video that the auxiliary was under the fuse box. So I took it all apart and like Geraldos tomb it wasn't there. Could it be some place else ?
Terrymo
Terry
2023 JLURXR 3.6 ET
If your Jeep is in original factory condition you probably have a 48 volt Etorque battery about the size of a small suitcase under the Jeep which still comes with an empty Auxillary battery box which is most safely accessed through the inner fender liner. Otherwise someone beat you to it. Take a quick look under your Jeep. This battery is not serviceable by the owner.
Jeep Wrangler JL Auxiliary battery help. IMG_4416
Waynev01
Waynev01
Wayne
Thanks ill look. It still takes that motorcycle size one correct?
Terrymo
Terry
2023 JLURXR 3.6 ET
No…one or the other. If you see the 48 volt Etorque battery under the Jeep you will not have a small secondary 12 volt battery from the factory. Just an empty auxillary battery box.
The 48 volt battery under the Jeep has an 8 year 80k mile warranty and is a fairly complex system including coolant lines and an inverter and is not something an owner should be messing with.
Waynev01
Waynev01
Wayne
Okay mines not a torque system. I just have the electric start stop motor.
hamiamham69
Nantucket MA
2019 Unlimited Sport
*IF* you do not have the 48V system and *if* your aux battery has already been removed, do yourself a favor and don't replace it. Its a terrible system, leads to the early death of batteries, and will leave you stranded once it fails.
Others may disagree but to normalize the practice of replacing 2! batteries every 2-3 years is just insane. My Jeep is the first vehicle I have owned in 40 years in which the batteries needed to be replaced after such short periods of time.
hamiamham69
Nantucket MA
You also should disable the auto stop / start if you have not already. Its annoying for one. It saves a de minimus amount of gas and puts X times the number of starts on your starter and engine. rant over
Waynev01
Waynev01
Wayne
I took all of it apart there isn't any cables to even hook another battery too. Its odd as hell.
Waynev01
Waynev01
Wayne
Lmao yes thats definitely next.
munkeymike
Tx
Did you buy it used? All JLs have either an aux, etorque or 4xe battery from factory.
Terrymo
Terry
2023 JLURXR 3.6 ET
So just to clarify and not to be insulting, you actually looked under your Jeep and did not see anything where the arrow in my pic is pointing?
I’m not talking about a plug in hybrid, just a different secondary battery system.
aeonixx1001
Kim
Arizona
2020 Jeep JL
If the removal of the Aux battery has already happened, you need to remove fuse F42. In fact if the person that took the Aux battery out did it correctly F42 should already be missing, check your fuse box. If its gone you arent using the Aux battery. This is the Power control fuse (f42)that switches ess on and off
Waynev01
Waynev01
Wayne
I'll look today, im completely new to all of this and slightly pissed. I traded in a Buick envision when I got this and I had to report all modifications. ( race suspension etc ) im sure they asked the same when the jeep came. I unhooked all of it just to see it all missing. Lol even the cables were removed. Its crazy. Good I guess but just odd. I now have to check to see if it has a Tazer ? Something about you have to use this to reprogram it when you remove the battery. No clue.
