Aux back up lights installed!
77RRAD
Ron
Las Vegas
2019 JLUR
Just installed some Rigid Industries SR-M lights on the Terra Flex 3rd brake light mount from there tire relocation kit. Since I already have AEVs CHMSL(Center High Mount Stop Light) modded and installed I was able to make this work with that part. Unplug 2 plugs and release the quick release and the lights come right off. you have to be able to open the tail gate to get to the plugs.
Jeep Wrangler JL Aux back up lights installed! 8ZDxZ0k
Jeep Wrangler JL Aux back up lights installed! CUbIqWi
Jeep Wrangler JL Aux back up lights installed! mbF42Ir
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
Nice... would you be so kind as to share where you picked up that quick-release? I've seen it before, but I can't find it and I'm curious if it'll fit for me since my spare is pushed out a bit.
77RRAD
77RRAD
Ron
Las Vegas
2019 JLUR
This is the piece that comes with the Terra Flex spare tire relocation. I don't believe it will work with anything else other than the Terra Flex part. The only reason I was able to make it work for the lights like this is because i used the AEV CHMSL from a JK and modified it to sit behind the spare.
melendez69
Marc
Waxhaw NC
...huh?
Ah... I see now... thank you for that info. Still good work there.
77RRAD
77RRAD
Ron
Las Vegas
2019 JLUR
That piece is actually for the 3rd brake light mount. you would use the stock light to mount in that quick release piece.
