Pennsylvania Adjustable lower front control arms
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
My two door 2020 Wrangler Sport S (JL) has Rubicon take-off axles (Dana M210/M220), an AEV Dual Sport 2.5” lift, and 35” tires.
I tried to schedule an alignment today. I called two shops that do trucks to see if they can align a Jeep. They both asked if I have adjustable lower front control arms.
I don’t. Apparently that limits the shops’ ability to adjust caster/camber (I did some digging and now I have [kind of] an idea what that means).
My AEV Dual Sport 2.5” lift came with geometry brackets. The jeep drove fine, or I didn’t notice any issues. However since I moved to 35s, steering and handling feels a bit off.
So in looking at options, I’m a bit perplexed.
Apparently the different designs can use rubber or polyurethane bushings. Where rubber requires greasing, and polyurethane does not.
Some designs have bushings on both ends, and some only have a bushing front and a “Y” at the frame end. I don’t have a clue about the Dual bushing versus single bushing designs.
Any recommendations for a newbie on what to get?
Pig-Pen
Banned Camp
2018 JLU
jabroni
the ones with a Y at one end are upper control arms. you adjust the caster with either uppers or lowers. camber is not affected since you have a solid axle. camber is the "butterfly" of the wheels when you have independent suspension.
first buy an angle finder and check the caster yourself, you may be within spec. if you have AEV lift and their brackets, you probably are. that's what the brackets are for.
so if anything, you may just need to adjust your toe which you can do fairly easily yourself. if it drove fine before the 35s, then it may be the air pressure you are running in the tires. i run mine at about 30psi cold. tire shops and the dealer put way too much air in the tires.
donmontalvo
donmontalvo
Don
Livingston, TX
donmontalvo.com
Thanks, I ordered a set of Currie control arms. They’re adjustable and have the Johnny joint on both ends. Unfortunately I don’t have the tools or knowledge to handle this on my own, but good info, learning a lot, thanks!
LSguy
Ohio
2021 Willys
What do you mean when you say handling feels a bit off? The handling will change when you move to a bigger, and more importantly wider tire. Different sidewall characteristics, higher center of gravity, more road contact area will all impact the feel. Too much air will make it ride stiff, will affect steering characteristics because you are driving on the center part of the tread. Lower air pressure rides nicer, but too low and it can start to feel sloppy or loose from sidewall play. Wider tires also generally tend to get pulled around more by groves in the road. If your alignment was fine before the tires, there's no reason it would be out now because you changed tires. If your jeep was out if alignment before the tires though, bigger tires can accentuate the problem and make it more noticeable.
