78c/NHTSA 25V-766 Recall
JeepSoxHuskies
JD
RI
2024 Wrangler JL 4xe
Just received notice that the engine may be contaminated with sand from the casting process. Sand from the casting process can contaminate internal engine components leading to catastrophic engine failure, which can result in a vehicle fire or inspected and unrecoverable loss of drive power.
This on top of the battery recall is getting out of hand.
Jeep Wrangler JL 78c/NHTSA 25V-766 Recall 1000103467
bthomp
Bill
Fort Collins, CO
2021 Wrangler 392 XR, 2023 Rubicon XR, 2010 Wrangler X, 2014 Mustang GT
IT Operations
And then they say "oh yeah, and a remedy is not currently available, but we'll let you know when one is"!?!?!?
That's CRAZY!
JeepSoxHuskies
JD
RI
That's CRAZY!
I reached out to the dealership because I had an appointment on Tuesday to review the battery but apparently that was a mistake. Discussed trading it in and they encouraged me not to (it's a lease) because of the value is so upside down that I basically would be screwing myself. Honesty at least.
Only-In-A-Jeep
North Georgia Mountains
2021 Jeep Wrangler Sport
Does this only apply to 2.0L engines in the 4xe power train?
JeepSoxHuskies
JD
RI
Yes they really did a rush jobs on these. Glad I "save" money on my hybrid I can't plug in. And not plugging it in my 4xe Willy's, I get worse gas miles than my V6 Willy's.
Only-In-A-Jeep
Thanks for the replies...and condolences to the 2.0/4xe people.
JeepSoxHuskies
JD
RI
Sadly I ended up in one because I wrecked my V6 pre2020 and post COVID pricing on the jeeps was crazy. Rebates put the 4xe in pre pandemic pricing. Regrets.
Sandevino
North Texas
2025 Wrangler Rubicon, 2002 Wrangler X
I’m going to call BS on the “casting sand” excuse here given the tolerances of these engines. If any foreign debris (sand or otherwise) was in the engine rotating assemblies it would fail quickly. Foreign material in fluid passages after assembly would get flushed and find a home in low spots of the coolant / oiling systems. I would expect to see more failed turbos or engines if debris were in them.
bthomp
Bill
Fort Collins, CO
IT Operations
That sucks… sorry man.
GinaC
Gina
Newport, VT
2026 Willys 2.0T 2DR Hard Top in Mojito built for me!
The Mopar website still shows my 2024 4xe with only the 68c recall.
Mine was built in August 2024. When was yours built?
JeepSoxHuskies
JD
RI
March 2024
GinaC
Gina
Newport, VT
alphawolff
california
2021 JLU
I'm inclined to think the same here. If there was some type of casting issue possible clogging up a fluid passage or damaging the turbo bearings themselves they would have failed pretty early into their service life. We don't see 2.0L turbo failures that often, and when we do it's usually a wastegate issue.
I guess we will see what the fix is. If it's to replace all the turbos I'm going to have a good ol' laugh.
tcadaniel
Pittsburgh
2024 JLU Rubi
I had a wrangler Sahara about 15 years ago that had this issue. It would blow hot air from one side of the vents and cold air from the other side. They determined it was sand in the block. They sent it to an outside vendor who flushed the whole system and found tons of sand. I can't believe that 15 years later they still have this issue.
