Iowa '23 JLUR XR Axle set
gek
Code Monkey
Set of axles off my '23 Rubicon XR. Took off at 33200 miles.
$4500
4.56 gear ratio
Local pickup only
I had a Willys that had a set of '24 392 axles that I took off when I traded it on this Jeep. I was going to put those on my wife's, but she ended up trading for a Grand Cherokee, so I put the full float and less miles axles in mine and am now selling my factory axles.
Price includes:
cast knuckles
control arms
2 tie rods (off this jeep and 392)
2 drag links (both pitman arm boots are torn)
front and rear track bars
rear sway bar
Front brakes Including calipers
Fad block-off plate
I do not have the rear brake rotors and calipers. I gave them to the guy that helped me swap them, but your rear rotor and calipers should work. I used the rear rotors and calipers off my '21 willys on my 392 axles without issue.
You can keep your FAD if you want just need to pull the block off plate and put your fad motor on it.
Front rotors are pretty rusted, so might not be able to use them.
Feel free to ask me questions about a swap if you need.
Would possibly consider a trade for a set of half doors.
Jeep Wrangler JL '23 JLUR XR Axle set 1780183954858-dn
Jeep Wrangler JL '23 JLUR XR Axle set 1780183968182-rg
Jeep Wrangler JL '23 JLUR XR Axle set 1780183982201-8q
Jeep Wrangler JL '23 JLUR XR Axle set 1780183995863-mm
Jeep Wrangler JL '23 JLUR XR Axle set 1780184026098-z8
Jeep Wrangler JL '23 JLUR XR Axle set 1780184044541-
Punkin_Moab
Mi
2019 Wrangler Moab
$4500
4.56 gear ratio
Local pickup only
Price includes:
cast knuckles
control arms
rear sway bar
Fad block-off plate
Planning to list on marketplace in about a week or so, but figured I would give the forum the chance first (and hopefully save myself from the people on there)
There is a scammer on FB that’s using your pics trying to sell your axles…
Jeep Wrangler JL '23 JLUR XR Axle set IMG_3412
Jeep Wrangler JL '23 JLUR XR Axle set IMG_3411
gek
gek
Code Monkey
Report them. I'm definitely not in Cambodia.
Also the AI fix for removing my name and date is something else. That one doesn't come with a pinion and a yoke apparently and the rear housing shape is completely incorrect.
I reported the post but there isn't much else I can do about it.
gek
gek
Code Monkey
and facebook says they reviewed it and are leaving it up. they wouldn't let me elaborate on why it was a scam
Jeep Wrangler JL '23 JLUR XR Axle set 2026-05-31 10_54_41-Greenshot
gek
gek
Code Monkey
Will be traveling to CO in early Sept. Could possibly rent a trailer and bring them along.
