Rusty Teeth
- Mar 16, 2018
- York,PA 17408
- 2021 JL Sahara Altitude
- Occupation
- Electronics Tech/ Fabricator/ 5G Fiber Optic Cellular Tech
Just up on 600 miles had it maybe 14 days.
2 days in had a no start, but would crank over problem.
Finally started, few more days left me sit. Had done some research.
Found all fuses loose in power distribution fuse box. Didnt help
Then found loose distribution cables from fuse box. Had 12.65 volts on N1. Main battery and 4.12 on N2
After good 5 hour charge.
Had it towed to dealer, service guy says, wonder if its the same thing as the last one. 30 seconds he comes back in and says yep needs ESS relay loose crossthreaded connections. What? Where?
Where did you wiggle?
Near the firewall under the battery?
Where? My tow truck driver said he got it started. Waiting for relay now.
Will post pix and issues i was seeing.
Found distribution lug not seated and possibly touching was loose!
Before and after alignment.
All fuses were also loose and needed seated.
Fuse identification under lid.
Will update soon!
Will update soon!
