lodoffroad
Get 10% OFF when you call and place your order (765-385-0631) LoD Offroad
Jeep Wrangler Destroyer Full-Width Bumpers are engineered to a higher level. The stealthy look and versatile functionality makes a bold statement while protecting and enhancing your off road Jeep on the trail. The increased features allow you to customize your Jeep like never before! The rear bumper has been upgraded with light bezels which allow easy light change out by removing a few screws. The Destroyer rear bumpers fit Rigid D-flush mount, Rigid D series, and Baja Squadron Series Lights LED lighting by switch out the bezels. Orders with no lights will receive blank bezels to fill the light housing cavity. The Destroyer rear bumper will work with the factory tire carrier and fits up to a 35" tire comfortably. Optional Tire Riser Mounts can be used to fit larger tire sizes with factory carrier. The tow hitch receiver is built into the rear bumper and is tow rated the same as the factory. (5000 Lbs.) Better look, higher quality, and more options!
Note: Tire Carriers can Not be Added to rear bumper only orders later!
New Features Include:
-New enhanced Destroyer bumper design with less catch points
-Fits 35" inch tire with factory Jeep carrier
-Riser mount available for 37" inch tires with factory carrier
-New enhanced light bezel design that prevents mud build up and easy to change lighting options
-Accommodates round or square Rigid & Baja Designs LED lighting options
-Stronger high strength/ light weight military grade steel
-More tire clearance
-Built-in replacement tow hitch receiver (Tow rated same as stock 5000 Lbs.)
Note: Bumper is shown with upgraded attachments which are Not included in the listed base pricing. All weights are of the bumper only with no options included.
For product information, please visit our website
https://lodoffroad.com/products/2018-jl-destroyer-full-width-rear-bumper-only
