2014 sahara keeps running hot
djkenb4
Kenneth
CO
2014 wrangler sahara
So I've had my entire cooling system replaced. 2 radiators, cooler fan, 2 water pumps, 4 thermostats and a head gasket. The damn thing keeps running hot still and I think it's the stupid thermostat because I can maintain the temp when I have the heat on full blast. Does anyone have any idea of how to fix this problem? I'm upside down in this thing so any advice is much appreciated.
kah.mun.rah
Merenkahre Jr.
Duat
Is your thermostat upside-down? Did you burp/bleed the coolant system when you replaced the parts connected to your coolant lines?
djkenb4
Kenneth
CO
I took it to Firestone and I asked those questions and they said yes. But that's what I thought it was put in upside down.
kah.mun.rah
Merenkahre Jr.
Duat
TBH I haven't replaced a thermostat in a 2014, and maybe it only goes in one way, but maybe worth checking to see if the hose between the thermostat and the engine gets warm or not when the engine reaches 200 degrees. My other comment about the burping is essential because trapped air in the system can get very hot.
djkenb4
Kenneth
CO
Good to know thank you
ShellNate7974
Nathan
South MS
2025 Wrangler Willys 4dr
Also, check your lower radiator hose. They sometimes collapse when they are old & won’t allow good circulation.
Is it overheating when idling only, or does it happen when you’re driving 30+ mph consistently?
djkenb4
Kenneth
CO
When I get up over 60 consistent
