2" Rancho Lift Kit How-To
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
@Tech Tim finished up another How-To write-up, this one on the Rancho Performance 2" Lift Kit:
http://www.northridgenation.com/rancho-2-lift-kit-for-your-wrangler-jl-install-how-to/
Rancho 2″ Lift Kit For Your Wrangler JL
Jeep Wrangler JL 2" Rancho Lift Kit How-To rancho-jl-lift-flexed-out-800x500
Lifting Your JL With The Rancho 2″ Lift Kit:
We’ve done a quite few lifts on Wrangler JLs here at the Northridge Nation/Northridge4x4 DIY garage, however there has been one lift we haven’t installed yet and have been looking forward to…. The Rancho 2″ Suspension System.
Not for any particular reason other than Rancho is one of those legendary names in 4×4 suspension and they are known to build a good lift kit.
How legendary is Rancho Suspension?
Rancho Performance was one of those companies that helped start the off road aftermarket parts industry. They started out as family ran Jeep parts and service business back in 1955 and progressed to their current status as one of the best known 4×4 suspension manufacturers in the world.
Originally called Rancho Jeep Supply and ran by father Clarence Shook, the small shop sold Jeep parts, designed many of their own parts and did Jeep build-ups. In the 1970’s, sons Gene and Keith Shook took the reins and Rancho Performance soon became the premier 4×4 suspension company of the time. Then in 1990, automotive parts giant Tenneco purchased the company and has held it since then, slowly growing and changing. Over the 60+ years Rancho has been around, they have seen a lot of changes. You could say that they have been there, done that and unlike so many of the other early day companies, Rancho performance is still around and still going strong.
What’s In The Box?
The Rancho 2″ kit Suspension Kit comes with variable rate coils, adjustable RS9000 shocks and all the brackets and components needed for the lift (including a pretty sweet parking brake cable reroute bracket that would be a great addition to any lift kit). We also added in the Rancho Geometry Brackets to get the caster back to the sweet spot. Some may say they are not necessary with only 2″ on lift, we sure like the way a lifted JL drives after installing the geo. brackets.
Jeep Wrangler JL 2" Rancho Lift Kit How-To ROS-RS66122BR9-1-2_Front
Rancho Lift components for the front of a Wrangler JL, PN# RS66122BR9
Jeep Wrangler JL 2" Rancho Lift Kit How-To ROS-RS66122BR9-2_Rear
Rancho Lift components for the rear of a Wrangler JL, all part of PN# RS66122BR9
Jeep Wrangler JL 2" Rancho Lift Kit How-To ROSRS62118B_1
Rancho geometry brackets ( PN# RS62118B.) to go along with the front lift kit.
For more information, here are the official Rancho Instructions: Rancho-2″ JL lift kit instructions.
Starting The Lift Kit Install:
Jeep Wrangler JL 2" Rancho Lift Kit How-To measure-before-height
First things first, establish your BEFORE pre-lift baseline. Measure all four corners, from the bottom edge of the wheel to the edge of the fender.
Jeep Wrangler JL 2" Rancho Lift Kit How-To BEFORE-measurements
Write them down on a sheet of paper and keep it for future references.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-jl-rear-track-bar
Start out by removing front and rear track bar bolts at the axle. It is easiest to do when the vehicle is still sitting on all four tires.
Also loosen up all the control arm bolts, front and rear. Don’t remove them, just loosen them a few turns to take any preload off of them.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-rear-shock
Remove both rear shocks. For the bottom mount you’ll need an 18mm socket and wrench, for the top mount, just the 18mm socket.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-rear-jl-sway-bar-link-2
Remove both rear sway bar links. They also need the 18mm socket and wrench.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-jl-rear-sway-bar-link
We ran into a little problem where we couldn’t get the nut off the upper sway bar link end. You normally can use a hex key in the end of the threaded shank to hold the stud from spinning. Ours was messed up by some previous ham-handed mechanic, so we had to grab hold of the shank through the boot with a set of Vise-Grips to lock it down.
We’ll be replacing the sway bar link with new longer Rancho units, so we weren’t too concerned with messing up the boot.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-rear-coil-jl-rubicon
With the track-bar bolt, shocks and sway bar links removed, the axle will drop down enough that you can easily remove the rear coil springs.
Jeep Wrangler JL 2" Rancho Lift Kit How-To install-rear-rancho-coil-jl
Install the new Rancho rear coil springs.
Jeep Wrangler JL 2" Rancho Lift Kit How-To rear-bump-stop-mount
Install the Rancho rear bump stop extension bolts right on top of the OE bump stop pads.
Jeep Wrangler JL 2" Rancho Lift Kit How-To always-use-locktite
Make sure to use a little Loctite 248 or some other medium strength thread-locking compound on all bolted suspension fasteners. It’ll help keep everything tight during your off road excursions and help seal the threads to help keep them from rusting together.
Relocating Your Parking Brake Cables:
Lifting your JL Wrangler can cause problems with the parking brake cable. It’s not a hug deal with the smaller lifts, though it is a good idea to relocate the cables below the rear cross-member to keep them from binding during droop.
Start out by making sure your parking brake is released!
Jeep Wrangler JL 2" Rancho Lift Kit How-To park-brake-cable-end
Use a pair of pliers to grab the end of the parking brake cable and wriggle it out from the parking brake lever at the brake backing plates. It is ‘S’ shaped, so you need to do a little forward and back twist to get it to come loose.
Jeep Wrangler JL 2" Rancho Lift Kit How-To jl-park-brake-cable-trick
PRO-TIP: Use a 13mm flare wrench to compress little tangs on the cable end and push/pull the cable through the bracket.
Jeep Wrangler JL 2" Rancho Lift Kit How-To unbolt-parking-brake-cable-bracket-copy-copy
Unbolt the OE parking brake cable retaining bracket from the body tub.
Jeep Wrangler JL 2" Rancho Lift Kit How-To relocate-rear-park-brake-lines-jl
Pull the parking brake cable from above the rear crossmember.
Jeep Wrangler JL 2" Rancho Lift Kit How-To park-brake-cable-drop-bracket
Bolt the cables to the Rancho parking brake cable extension bracket.
Jeep Wrangler JL 2" Rancho Lift Kit How-To park-brake-cable-relocation-finished
The Rancho drop bracket then bolts up to bottom of the crossmember.
This part is pretty cool and we’ve got to give Rancho big kudos for this bracket, it works great and keeps the parking brake cables from flopping around.
Jeep Wrangler JL 2" Rancho Lift Kit How-To Installing-rear-rancho-shock-jl
Install the new Rancho RS9000 shocks into the JL. One trick we use on the JLs is to switch out the longer lower shock bolts with the shorter lower sway bar link bolts, this will protect that long threaded bolt end from getting damaged off road.
Jeep Wrangler JL 2" Rancho Lift Kit How-To install-rancho-extended-sway-bar-links-jl
The new extended length sway bar links can go in next. Then double check all your connections and move to the front suspension.
Installing the Ranch Lift on the Front:
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-track-bar-bolt
Just like the rear, remove the front track bar bolt at the axle.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-brake-line-brackets
Remove the nut holding the front brake line bracket to the front lower control arm.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-front-sway-bar-links
Remove the front sway bar links. These will also take an 18mm socket and/or wrench.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-lower-shock-bolt-jeep-jl
Just like the rear shocks, you’ll need an 18mm wrench and 18mm socket to remove the upper and lower bolts holding the front shocks in place.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-stock-jl-front-coil
Lower the front axle down until the coil springs are loose enough to remove them.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-control-arms
Support the front axle securely and remove the front upper and lower control arms at the frame side. It is usually easiest if you do only one side at a time.
Jeep Wrangler JL 2" Rancho Lift Kit How-To remove-UCA-heat-shields
The upper control arm pivots at the frame are covered by heat shields, use a 10mm wrench to pull the two screws holding the in place. One screws is towards the bottom, the other is up on top, so you’ll need to practice your blind faster removal skills to get that one.
Jeep Wrangler JL 2" Rancho Lift Kit How-To install-geometry-bracket
Install the geometry brackets into the stock controls arm frame mounts and then install the controls arms into the Rancho geometry bracket and snug up the hardware.
Do not tighten the control arm bolts or the geometry bracket bolts until the Jeep is sitting on all four tires on the ground.
Jeep Wrangler JL 2" Rancho Lift Kit How-To geometry-bracket-jeep-jl
As you lift your Wrangler, you will change the angles of the suspension control arms, which changes the arm geometry originally designed by the Jeep engineers. Geometry correction brackets help to bring those links back closer to your original geometry.
The red arrows show how much the controls arms have been moved down from their factory position to bring the suspension geometry back closer to stock.
Jeep Wrangler JL 2" Rancho Lift Kit How-To installing-rancho-front-jl-coil-sprin
Slide the Rancho bump stop spacer into the coil spring and install the new Rancho front coil springs into your JL.
Jeep Wrangler JL 2" Rancho Lift Kit How-To zip-tie-front-jl-bumpsto
PRO-TIP: Once you have inserted the bump stop spacer up into the coil spring, zip tie it to the coils, this will hold the bump stop spacer out of the way while you install the coil springs.
Jeep Wrangler JL 2" Rancho Lift Kit How-To installing-front-bumpstops
With the new coil springs in place, remove the zip tie, set the bump stop spacer down on the stock bump stop seat and bolt it in place.
Jeep Wrangler JL 2" Rancho Lift Kit How-To installing-jl-front-rancho-shocks
Install the Rancho front shocks with the original hardware.
Jeep Wrangler JL 2" Rancho Lift Kit How-To install-front-jl-sway-bar-links
Install the new extended sway-bar links and you are almost done with the lift.
Finishing Touches:
Reinstall the wheels and tires on and get the Jeep sitting on all fours at static height, do the final torque on all the control arm and geometry brackets. This locks everything at the ride height (neutral position).
Don’t forget to adjust the draglink to recenter your steering wheel and keep the dash from lighting up like a Christmas tree. Click here for a quick step-by-step on how to recenter your JL’s steering wheel after a lift.
We do recommended to have an alignment done to make sure that your Jeep is tracking straight and true down the road.
Don’t Forget Your AFTER Measurements:
Jeep Wrangler JL 2" Rancho Lift Kit How-To FINISHED-mojito-jlur-with-rancho-lift
Make sure to park your Jeep on level ground and take those AFTER measurements. Then add them to your earlier notes.
Jeep Wrangler JL 2" Rancho Lift Kit How-To rancho-lift-after-measurements
These AFTER measurements seem a little high at first, but this is after the kit was first installed. These numbers will definitely drop closer to the 2″ height after the first good wheeling trip.
Showing off the flex of Rancho 2″ Lift Kit for the Wrangler JL. Fully loaded and flexed like this over a few local trails were all it took to settle the suspension to the 2″ lift height we expected.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
Would that kit work on the sport JLUS (4 door)? I also did see just the shocks for 0-2 inch lift only, My jeep is all stock.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
We have 5 of these lifts installed on JLURs in my group. We wheel all over the US. We run 37s and have done 32 Jeep badge trails and many others around the US. We have done Holy Cross, Pritchett Canyon....all the badge trails in Moab, the Rubicon Trail, sand dunes and wheeled at Windrock and Rausch Creek. We have over 150,000 combined miles on the Rancho lifts and they have exceeded our expectation. We have broke some from sway bar links that Rancho replaced for free. The other problem is we scrub the plastic adjuster knobs off the shocks occasionally. The knobs are about $10 dollars and easy to get and easy to replace. The lift has great on road and off road manners. When people ride in my JLUR for the first time they always say, "I thought this would ride rough, but it is more like a nice passenger car." I turn the shocks down soft on the street and turn them up for the type of trails that I am running for that day.
I do not think you can buy a better lift for double the cost of the Rancho kit. A few pics of our Jeeps wheeling
Jeep Wrangler JL 2" Rancho Lift Kit How-To 1611322615274
Jeep Wrangler JL 2" Rancho Lift Kit How-To 1611322642904
Jeep Wrangler JL 2" Rancho Lift Kit How-To 1611322781202
Jeep Wrangler JL 2" Rancho Lift Kit How-To 1611322829876
Jeep Wrangler JL 2" Rancho Lift Kit How-To 1611322916309
I could post 100s of pictures, but hey if you need a lift and a company that stands behind their product, give Rancho a try.
XxsullyxX123
Somers, NY
2020 JLU Rubicon Recon, 2020 Honda Pilot Touring
I loved the rancho 2” on my JKUR. Just what I was aiming for for 33’s at the time. I’ll probably do the Rancho 2” kit on my JLUR Recon as well, and either 35 or 37 ridge grapplers. I was set on 35’s given this is a daily driver, but the 37’s come in D load range vs the E on the 35‘s so I may up the size. I’ve personally already done the Mopar longer LCA’s to up the caster. So i likely wont need another thing, other than hold the rear fender liners if I do the 37’s.
