diesel_dave
Utah
2023 Rubicon 4xe
Been anxiously waiting for my Forest River R-Pod 180 to show up at the dealership for the last few months. On paper, this trailer is right about at the max of the Wrangler Unlimited's legal tow rating of 3,500 pounds with 350 pounds of tongue weight. The RP-180 with beast mode package has a dry weight of 3327 pounds and around 330 pounds of tongue weight.
I had been stressing out that this would mean the trailer would be a white knuckle nightmare to tow and that I would end up only wanting to tow it with my other truck (2007 Yukon XL). This would have defeated the entire purpose of downsizing from a 24' toy hauler to this much smaller unit: so I could tow a reasonably comfortable camper out to the trails with the Wrangler.
I nervously signed the paperwork, inspected the trailer, and then went out to get it hitched up. For some reason, there really aren't a lot of posts or YouTube videos of people towing with Wranglers. Even fewer with JLs and even fewer with JL 4Xes so I was expecting the worst. I really thought the ass of the Jeep would be basically dragging on the pavement with this much tongue weight based on some of the limited comments I had read about towing with a Wrangler. Well, to my surprise, as I retracted the jack, the back end only dropped maybe 2" or so. I even jumped up and down on the bumper in case it was just bound up, because I thought there was no way that was all it was going to sag. My old trailer on the Yukon would drop it probably 4" before the air suspension would level back out so that the Wrangler only dropped an inch or two was really surprising.
I was running late and needed to drive back home 40 miles so I could unload the trailer at home and get to work, so I decided to take my chances and drive it home without taking all the time to install and adjust the weight distributing parts of the hitch in the dealership parking lot. If it was too unruly, I would just pull over somewhere and do all that so I could get it home.
Well, I pulled out of the dealership lot, adjusted the setting on my Curt Echo bluetooth brake controller until it felt right then pretty much got straight on the freeway.
Let me tell you, power is *not* an issue with the 4Xe. I definitely felt like I could accelerate hard enough that unsecured items in the trailer would be thrown around. So one of my major concerns about moving nearly 9k pounds total GCWR with a 2.0L was put right to bed.
I had arrived at the dealership with around 50% battery left on purpose so I could get a mix of full hybrid performance and later on once the battery was depleted, the performance of just the 2.0L doing everything itself. While there was still battery left, the rig was a rocket and you could very easily maneuver through traffic.
Once the battery was empty after about 10 miles of driving in blended hybrid mode, the computer will still use the electric motor for short blips of "boost", but eventually the HV battery will get low enough during sustained high load driving that it will be nearly 100% on the little 2.0L to keep things going. Even in that state, I never felt like I didn't have enough power. The engine spent most of the time in 7th or 8th gear just chugging along at 2k RPM and never sounded like it was going to blow up or anything.
The transmission did an excellent job at picking the right gear for the situation and not shifting excessively despite there not being a TOW/HAUL mode button.
I used adaptive cruise control in the right lane set to 65 MPH the entire drive home and the highest temps I saw after a bit of a hill climb with 82 degree ambient air temp was 220 coolant, 196 trans, and 222 oil which I was more than happy with. The adaptive cruise worked great even with a trailer, the blind spot monitoring still worked, but didn't reach back behind the camper like it did on my Ram 3500. On flat ground, I was seeing around 17 MPG while there was battery charge left and around 12 MPG once the HV battery was empty. I'll hand calculate these values on the next trip I take to see how close the guess-o-meter actually is to reality.
Even more surprising to me was how the whole rig felt going down the road at 65. Like I said earlier, I was pretty sure it was going to be a two hand, white knuckle experience based on some things I had read about other people towing with the Wrangler. Well, that couldn't be farther from the truth. After a few miles on the freeway was able to almost completely relax and keep everything completely in control with just one hand on the wheel and minor corrections when a truck flew by 20 MPH faster than I was going. I even aimed for a few deep potholes just to see how it behaved and it was all very well damped with no more than one or two very minor oscillations. There was so little sway and pogoing that I am debating whether I will even bother hooking up the WDH and sway bar for my upcoming trip to Washington.
TL;DR: The 2023 Wrangler 4Xe has PLENTY of power and suspension to handle a 3,300 pound travel trailer easily and confidently.
Jeep Wrangler JL First max tow w/ Wrangler 4xe went way better than I ever could have expected (towing Forest River R-Pod 180) 20230607_122644
Alan W
Alan
2023 Wrangler High Altitude
cool to hear your experiences towing the trailer. i too am looking to buy a travel traliler and tow with my 4xe High Altitude.
What size tires does your wrangler have?
diesel_dave
Utah
2023 Rubicon 4xe
It's a totally stock Rubicon so it has 33" KO2 tires.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Make sure you adjust your headlights, super easy with just a screwdriver so you don't get flashed at night.
Even with 37s on the stock 4.10s it's not a bad experience actually doing the pulling.
This certainly could be an installation related issue, but I did have one of my new Timbren brake/bearing assemblies fail after about 6k miles. I still have some concern that it was at least partially due to a combo of max regen/adaptive cruise as my brake controller uses the lights and not the brake pedal for actuation (AuTowBrake).
Overall, I'm sure your biggest concern will be the same as mine, the tiny gas tank.
MoparFan
Jim
Alabama
‘23 Rubicon 3.0, 1970 e bodies
Great write up. Thanks for taking the time. Any chance for some pics of the hitch assembly you ended up with and a few of the camper interior would be great as well:)
lightsout
PNW
Driving straight down the freeway is not an issue swerve to avaid something and see how that tail wags the dog. The Wrangler cannot handle that. By the time you add the hitch you are 3400+lbs with no gear on board. The Wrangler 4xe has a GCWR) gross Combined Weight Rating) of 9200lbs that is your limit (not 3500lbs). Until you scale both rigs tou may or may not be legal. many states are now having random days for requiring RVS to go through weight stations, be over the GCWR you may be camping in the weight station parking lot till a tow vehcle arrives to legally tow your RV. problem is you need to weight fully loaded including fuel, passengers/driver/pets, hitch, gear, food, water, Black/Grey. It all adds up. The other factor towing beyong limits is transmission wear especially if you do not have the right gears. It is not the 99% of towing time that is the problem it is the 1% that can be catestrophic. Get in an acident and a simply google search will tell the other party or law nforcment you you were illegally on the road.
Fgonzal2
Frank
Albuquerque
2022 Wrangler 4XE High Altitude
I have an identical 4xe color and all and am pretty close to getting an r-pod 190. The dry weight is 3208 so it will not be a problem. @diesel_dave insight actually helped with my decision! I plan to get a good WDH either blue ox or Andersen.
Oncorhynchus
Moishe
San Jose, CA
2018 JLU Sahara Sting Gray 3.6L
lightsout
PNW
Oncorhynchus
Moishe
San Jose, CA
That does not help the pre 2024 model years like the OP has.
Agree. Would not take the chance if it were my vehicle and my life on the line. Yes, in regulated industries like the automotive industry there are standards-based safety factors built into the publishable specifications but again those standards are there for a reason.
MaximusW
Maximus
Southern Utah
'24 4xe Rubicon X (Anvil)
Creative Director
Moving to semi-retirement prompted me to order a ‘24 4xe Rubicon X and AntiShanty off-road trailer. My trailer won’t be quite as heavy as your R-Pod, but not too far off. I was curious what I should expect from a power and mileage stand point, so I really appreciate you sharing your experience. Thank you.
GATORB8
CLT NC
Well, looks like Jeep advertising didn't make it to the OM before the publish date:
Jeep Wrangler JL First max tow w/ Wrangler 4xe went way better than I ever could have expected (towing Forest River R-Pod 180) 1687210666280
Jeep Wrangler JL First max tow w/ Wrangler 4xe went way better than I ever could have expected (towing Forest River R-Pod 180) 1687210648611
Realistically, the limiting factor is likely wheelbase and COG. These things literally are body on frame solid axle trucks, and they weigh out as such.
If you misload a trailer on anything, it's gonna wag bad. That's the most important piece.
Yes, if you're over the OM GCWR, you open yourself up to liability, but I'm not a cop. With all the overloaded crap all over the road, I'm just happy if you load your trailer right, understand how to tow it safely, and drive semi-resposibly.
I will admit that I pulled our trailer (lighter, but on 37s) back home this weekend across the BRP and down the Devil's Whip. So you may be taking your life in your hands listening to anything I say, lol.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Congrats! Careful filling too much payload in your trailer. That weight adds up quick. Think about each item you pack.
skeptacular
OR
2018 JLU Rubicon
We've gone back and forth about buying an RV and finally decided we probably will not, at least for some years, which is part of why I sold my truck and ordered a JL from CarMax (still not here). However, if I do end up buying one I'll be looking for something under 3,500lbs gross weight, not dry. I'm not going to scold you or call you names like some other forums would, you do you, but I will say if you are trying to stay under max tow ratings you can't go by dry weight. You are going to be adding gear, propane, water (clean, black and gray), food, etc.
