DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today
kurt13
Kurt
Montgomery, TX
Red JLU Rubi/4Runner
Like the thread title says, I installed the soft top today. Here are a couple of helpful hints I wish I knew. By the way, I have no idea if the JL is anything like the JK. The last soft top I put on was a YJ and Bush Sr. was President so if this is common knowledge, forgive me.
In the big box, there are a few plastic bags of parts and hardware. There are three types of bolts.
The smallest bolts are used to connect the L- and T-sections of the rear door surrounds (2 per 2 sides), attach the plate to the rear bar (2 per 2 sides), and attach the Lift Assist Mechanism to the same plate (2 per 2 sides).
The mid-sized bolts go on the back to secure the rear corners (1 each per side) of the soft top.
The longest bolts are used to clamp the door surrounds to the sports bar- 2 per door x 4 doors.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-03 10.10.34
In the first step, there are 6 (3 per side) plastic door surround pieces. I wish I took pictures when I started, but I didn't, so you'll have to see them in place/assembled. The manual says to start with the front. The surrounds go on the outside of the bar with the hinges on the bottom/outside. Use the longest bolts to go up from the bottom of the surround, through the bar, and into the receiver hole on top.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-03 10.13.11
When mounting the front, it should set into the gasket at the front windshield.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-03 10.14.21
Now we install the rear seat door surrounds. The T shaped piece joins the L shaped piece using two of the short bolts per side. There's also a small weird-shaped rubber gasket that goes between them. Once this assembly is together, connect it to the bar just like the front with long bolts.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today Slide2
Here's the gasket installed already-
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today Slide3
When you install the rear door surrounds, they mate up with the front ones. Make sure the gaskets are all smooth:
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-03 10.14.25
Now we'll move to the back of the Jeep. The quarter window "anchors" go on the rear corners with medium (not longest) bolts.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-03 10.08.31
Next come the only metal plates in the soft top box. The owner's manual doesn't even mention them that I could see. You have to remove a trim piece from your rear bar first.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today panel
To pop the trim off, stick a flat head screwdriver down behind it to pinch the trim tabs. You can see I bent one during my struggle-
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-02 16.04.00
It will reveal this. Using the shortest bolts in the box, you connect the metal plate here. It's obvious how to align it. The plate has an indexing pin that goes into the hole here.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-02 16.03.45
Use 2 short bolts to attach the plates to the inside of the rear bar. It'll look like this.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-03 10.00.16-1
Then you'll lift the soft top into place and align the box (the Lift Assist Mechanism) to the plate. This is the only step you really could use a buddy to help out. It's really awkward to hold the top and reach the bolts from the outside of the Jeep. Two more short bolts on each side and you're almost there.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today Bolts
After that just follow the last couple of steps in the manual- pull back the slide, mount the pins, and release. Pretty much done!
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today 2018-03-03 10.25.42
Happy Jeeping!
:jk::jk::jk:
vhfan5150
Sean
Cincinnati
Bright White JLU Rubicon
Thanks for posting this. I plan on tackling this once this Ohio weather decides if it’s not gonna be like Ohio weather, so probably June. Also, I don’t know if it’s on my end or not, but pics 1-5 and 7-10 did not come through.
kurt13
kurt13
Kurt
Montgomery, TX
I see them when I view the post. Please let me know if others have a problem.
Man-of-methods
Paul
2018 Jeep Wrangler JLUR (His) 2018 Jeep Wrangler JLUS (Hers)
The same pics didn't come through for me as well. Nice write up though. Thanks
sfadchi
Wellington, FL
18' Bright White JLUR
Corporate Recruiter
Pics broken for me too.
jericbarg
Rainbow City, AL
JLUR-Granite
Healthcare
Excellent write up Kurt!
How is the wind noise/buffeting compared to the hardtop?
vonbek
Georgia
I see some pics which appear to be hosted on the forum, and other pics are missing which appear to be hosted at googleusercontent.com.
Vee
Vito
GTA Ontario
Toyota RAV4. BMW 328
Pics missing. Excellent write up. I’ll use your post when I install mine
Smarrtazz
Trina
Fl
Lagertha 2018 JLUR Sting Gray ;)
The smallest bolts are used to connect the L- and T-sections of the rear door surrounds (2 per 2 sides) and attach the plate to the rear bar (2 per 2 sides).
In the first step, there are 6 (3 per side) plastic pieces. I wish I took pictures when I started, but I didn't, so you'll have to see them in place/assembled. The manual says to start with the front. The surrounds go on the outside of the bar with the hinges on the bottom/outside. Use the longest bolts to go up from the bottom of the surround, through the bar, and into the receiver hole on top.
When mounting the front, it should set in to the gasket at the front windshield.
Now we install the rear seat door surrounds. The T shaped piece joins the L shaped piece using two of the short bolts per side. There are also a small weird-shaped gasket that goes between them. Once this assembly is together, connect it to the bar just like the front with long bolts.
Jeep Wrangler JL DUAL TOP HOW TO: I Swapped the Hard Top for the Soft Top Today {filename}
Next comes the only metal plates in the soft top box. The owner's manual doesn't even mention them that I could see. You have to remove a trim piece from your rear bar first.
http://data:image/gif;base64,R0lGODlhAQABAIAAAP///wAAACH5BAEAAAAALAAAAAABAAEAAAICRAEAOw== To pop the trim off, stick a flat head screwdriver down behind it to pinch the trim tabs. You can see I bent one during my struggle-
Then you'll lift the soft top into place and align the box (the Lift Assist Mechanism) to the plate. This is the only step you really can use a buddy to help out. It's really awkward to hold the top and reach the bolts from the outside of the Jeep. Two more short bolts on each side and you're almost there.
Happy Jeeping!
:jk::jk::jk:
Not all of the images showed up for me, as well. Great write up! How did you find the process? Easier or harder than you had imagined? Where did you store your hard top?
zodleviton
Chandler, AZ
...still waiting
Like everyone else, thank you for the write up! If you could please try to post the pics again, I'm sure we would all appreciate it.
RussJeep1
Westchester, NY
JLU Sahara
Kurt: mighty fine of you to post your lessons learned for the rest of us!
kurt13
kurt13
Kurt
Montgomery, TX
Hey guys, sorry for the technical difficulties with the pics. I tried to reload them all in the first post. Can you see them now?
Man-of-methods
Paul
Yes
kurt13
kurt13
Kurt
Montgomery, TX
Can't say. I haven't gone over 60 in either one. I've only driven in safari top mode- no side or rear windows. I'm avoiding the highway because a) break-in period and b) it's the highway.
