shane h.
First addition in a bit. Installed a pair of Baja Designs Squadron Sport pods (wide cornering lens in amber) on some Motobilt A-pillar light mounts that I sprayed black with a bit of Steel-It spray.
I'll add some pictures when I get somewhere other than the garage. We've all seen ditch lights. More fun to use than to look at.
The BD Squadrons came with a complete wiring harness including on/off rocker switch pigtail with white, blue, and black wires. I removed the switch, covered the white wire, hooked the black up to a good ground, and hooked the blue up to Aux4 on my Lasfit switch panel. Hooked the main harness ground to a good body ground, and hooked the main power up to the battery positive terminal. I left the supplied relay inline even though the Lasfit switch is also relayed.
