General
Northridge4x4 Giveaway: Rock Krawler JL Adventure-X Series 1 Suspension System
Northridge4x4 is currently running this great giveaway for the Rock Krawler JL 3.5 or 4.5 Adventure-X Series 1 Suspension System. These are not even available on the market yet!
Features and Benefits of the suspension systems:
  • Excellent Highway Ride and Handling
  • Unreal Off-Road Performance
  • Full High Clearance Long Arm 4 Link Front Suspension
  • Independent 3 Link Rear Long Arm Conversion Featuring X2 Geometry
  • High Clearance Rear Axle Bracket Kit with High Clearance Rear Lower Control Arms
  • Best Ground Clearance and Cross Over Angle in its Class – Rear Upper Shock Relocation Brackets
  • OEM Style Weld Scheduling and Heat Shield Products for Frame Side Mounts
System Includes:
  • Triple Rate Coils Front and Rear
  • Adjustable Track Bars Front and Rear
  • 4 Adjustable High Clearance Lower Control Arms
  • 2 Adjustable Front Upper Control Arms
  • Front and Rear Long Arm Mounts
  • 3 Link Rear Conversion Mounts
  • High Clearance Rear Control Arm Axle Brackets and Adjustable Track Bar Mount
  • Double Adjustable Rear Upper Third Link Arm
  • Adjustable Front Sway Bar Disconnects
  • Adjustable Rear Sway Bar Links
  • Spring Correction Seats Front and Rear – Heat Shield Products
To enter, see the giveaway contest thread for instructions.
