Heimkehr
- James
- Sep 3, 2020
- Pennsylvania
- 2021 JLU 2.0T
5.5 quarts is the amount of fluid that should drain out during each service. The same volume should be pumped back in each time, also. This is why at least two fluid & filter changes are recommended (3 is best), so as to maximize the replacement of old fluid with new.kind of tedious especially lining up the filter with the trans, we were going at it for a few attempts but go it.
Overall about 5.5qts went back into the trans. But didn't measure the fluid coming out.
Tips for next time, unless you've already done so:
1. The two magnets in the pan should be removed, thoroughly cleaned and reinstalled.
2. The two nuts that secure the transmission filter should be snugged, and then backed off barely half a turn...just enough to allow a bit of fore & aft movement, which will in turn make aligning the filter's neck with the corresponding port on the underside of the transmission body that much easier. This is stated in the instruction document that accompanied the filters that I purchased.
Also...what are we looking at in the first two photos? Did you cut open/disassemble the original filter assembly?
