Olyclimber
- Andy
- Aug 14, 2018
- Olympia WA
- 2018 Ocean Blue JLUR , 1972 Waggy
- Vehicle Showcase
- 1
I recently ran into the Diff Locker issue that has become common for so many JL Rubicons.
Thanks to the members here I learned of the Z Locker OEM work around and quickly ordered one, problem is mine doesn't fit on the differential side of the plug. I'm not above the occasional simple user error but after investigation (and carefull review of instructions) I see that the plugs alignment/orientation pins is located in a different position then the connector in the diff. Has anyone else had this issue? The Z locker OEM is on the left side of pic. The right side is the connector from the diff. I've reached out to Z Automotive to sort this out but haven't had any contact to date. Its been 48 hours.
