benny_rt2
- Benny
- Mar 20, 2018
- Baton Rouge Lousiana USA
- 1989 YJ - 1999 TJ - 2004 TJ
Hi,
Does anyone know if Yukon Gear sells or are they planning to make the Superjoint in 5-7166X, the size ujoints in the Wrangler JL front axles? I couldn't find it on their website or in vendor websites. I would rather use superjoints than regular Spicer 5-7166x, otherwise I may go to a CV type instead of ujoint axle.
I’ve been using Yukon 5-760X Superjoints in my TJ front chromolly axle ears since about 2006 or so and I would love to put Superjoints in a new Jeep JL too.
Prior to the Superjoints in my TJ I had spicer ujoints fail inside chromolly axle ears, and it was a pain when it happens. Trying to remove the twisted shaft ears and ujoint from the axle housing while on the trail took hours. Sometimes the fractured ujoints can get jamed in the ears really good and make extracting the shafts from the tube and through the knuckle very difficult, especially on thee trail. But after upgrading the TJ to Superjoints I hadn’t had a ujoint failure since which is why I’d like to upgrade a JL with superjoints too.
Else I may try a CV type, but heard of them failing too. I never read of a Yukon Superjoint breaking. I've twisted splines, and broken gear teeth, but never heard of a superjoint itself failing.
I've sent Yukon Gear an email asking them about a 57166X superjoint. I'll post their response when I hear back from them.
Thanks
Thanks
