PavementWarrior
For those suffering, and mopar engineers should take a look:
Sure I agree, and people with stock setups should not have to put aftermarket steering components to be safe.As much as I love beefy aftermarket components, it can't guarantee to solve everyone's death wobble issues. It can definitely correct lift geometry for sure, but so do every other adjustable aftermarket products.
Yes I saw it and shared it on our fb page. That’s exactly what ours is doing. I’m hoping this is the solution. I ordered two kits that should be here Thursday. Going to install as soon as they do, I miss driving the Jeep. Installing the second kit on Friday. Have a feeling I need to keep a couple in stock if this is the fix!
That recall and tsb rumor has been circulating for 20+ years. Not happening.Sure I agree, and people with stock setups should not have to put aftermarket steering components to be safe.
Also, obviously this is a step you take after going through the usual list of suspects (ie algnment, tire balance, mopar finger tight bolt technology)
However, new Mopar parts are appearing, and current speculation is there will be a recall or tsb shortly. People who have lifts, or not waiting for a new mopar part and having to convince dealer to install it, might want to fix sooner.
I’ll agree with you. I think a lot of folks get a shimmy and think it’s death wobble at first. If they ever get the real deal, they will know the difference. My geometry is spot on, everything is tight and nothing is worn but yet my jeep is parked until my steer smart stuff comes in. I cannot nor can anyone else figure out what the problem is and I’m to the “throwing parts” part now and hoping it’s fixed. DW 99% of the time is something simple. Other times it’s a bear to track down.The video was clearly a Jeep with an issue, but I believe what many think is death wobble in their JL is just first time experience with a solid front axle and gripping the steering wheel too tight over bumps. There is a feel to driving a Wrangler that isn’t like a car. I may be wrong (have been, will be again), but I think some of these DW claims are naively exaggerated.
Some of this death wobble issue is also from lifts that get suspension geometry out of spec and prematurely wear bushings and joints.
the new parts from mopar are real. new trackbar just coming out, will see if its any better and if it will be included.That recall and tsb rumor has been circulating for 20+ years. Not happening.
JL is having issues period. People are seeing high speed shimmy, Wobble, and wandering all way out of normal and confirmed by multiple dealers.The video was clearly a Jeep with an issue, but I believe what many think is death wobble in their JL is just first time experience with a solid front axle and gripping the steering wheel too tight over bumps. There is a feel to driving a Wrangler that isn’t like a car. I may be wrong (have been, will be again), but I think some of these DW claims are naively exaggerated.
I’m definitely not dismissing the whole issue here, just saying it may not be as widespread as it seems and can be caused by a variety of issues.JL is having issues period. People are seeing high speed shimmy, Wobble, and wandering all way out of normal and confirmed by multiple dealers.
Mine had high speed shimmy, stock, at around 1500 miles, I have driven many solid axle vehicles. Only thing I have driven worse was an old 1950s 20 ton Hyster Forklift. I had a 1985 Toyota pu that could kinda pop over 3 feet on a bump, but that was oddly less scary than this shimmy cant steer bs
Agreed, funky tire pressures, loose bolts, bad alignments are the place to start checking not after market. Anyway you slice it its an interesting video for anyone having these problems, and already been to dealer a few times.I’m definitely not dismissing the whole issue here, just saying it may not be as widespread as it seems and can be caused by a variety of issues.
I’ve seen your videos and followed your build. You obviously don’t have DW or have never experienced it. The steering stabilizer is designed for driver comfort, not to prevent death wobble. If the steering is correct, you don’t need one however, it makes for a smoother experience by absorbing the jarring or shock of the road.Not to be difficult, but you took the factory steering stabilizer off to try and induce death wobble. Why not try to induce it with the SS? Are you saying that your JL is completely stock or unmodified in any way and had actual death wobble?
I believe that dealers can’t replicate it a lot of times because it may be just the driving characteristics of a Jeep vs let’s say a Tahoe. I haven’t followed it enough but are there stats on the number of reported vs confirmed cases?
