Yellow/amber offroad/fog LED lights?
AMG
AMG
Upstate New York
Mercedes-Benz CLA45 AMG, BMW G650GS
Update:
I tried to install the Lamin-x today. Per the instructions, "the Lamin-x is very forgiving; you can remove and re-install numerous times until finished." Well, the first time I tried to remove the Lamin-x as it was off-center by about a millimeter, an application tab ripped off, ruining the cover. As they only gave me two covers, and one of them ended up damaged following their instructions, I'm out $16 and still don't have yellow fog lights.
Obviously others have had success with this product, but I won't be buying Lamin-x products again.
Bearded_Dragon
FL
2018 Mojito! Rubicon
Update:
I bought a 12x48 sheet of vinyl off Amazon for $7 shipped, look on there if you want to try again. I'm sure there are cheaper options on eBay and Amazon too.
55WillysWagon
Jon
1955 Willys Wagon, 2019 Jeep Wrangler OB JLUR
Any issue installing given the curvature of the OEM lense? Any bumps created? Wet or dry install?
Punkindave
Bethlehem Township, PA
2019 JLUR 2.0 Turbo Bluebicon, 2020 JLUR 2.0 Turbo (Wife's)
ITS Project Manager
Two slight puckers, a little heat on the low setting took it out quickly. I may have been able to do it without, but the heat gun was already out.
55WillysWagon
Jon
Thanks for the heads up. May attempt install tomorrow.
55WillysWagon
Jon
Did you remove the fog light to install?
Edit: NVM, quick remove and replace. 20 minutes tops. They went on fine. Seems like they don't go on perfectly smooth, tiny tiny bubbles behind the film. Maybe a wet install would have been better. I'll run them for a bit and see how I like them. Plenty rainy here in the Boston area.....omg.
johnnymiz
Long Island
i did not remove mine. took all of 2 minutes. had to reset one edge on each... no biggie. no bubbles
emilboya
Emil
TX
Hummer H3 (Sold) & Jeep JL
Process Engineer
Exactly what I did on mine, works fantastic. My fogs were useless in a snow storm due to reflections from the stock led white lights now the yellows cut right through it.. Works
Jeep Wrangler JL Yellow/amber offroad/fog LED lights? 20190508_220720
well for night wheelin as well.
Does the light color come out greenish?
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
You can always install 3k LED bulbs if you want the yellow fogs. I did that with my WK2 when I replaced the halogen bulbs w/ LEDs.
