Xtreme Recon Questions!
ssrgeoff
PNW
2021 JTR, 2022 JLURD
Question as it relates to the XR package... If the axle is beefed up compared to your standard Rubicon, is it the wall thickness or a bigger tube all together? Would the EcoDiesel use the same front axle as the XR package or Rubicon?
kah.mun.rah
Merenkahre Jr.
Duat
I will not try to defend the concept they are "just fine" either.
I never asked you to defend it. You decided to debate it. For me it works just fine so why am I not allowed to say that?
I have used
31s w/ 3.73
32s w/ 3.73
33s w/ 3.73
35s w/3.73
37s w/5.13
32s w/ 4.10
35s w/ 4.10
37s w/ 4.10 (on two different Jeeps)
CarbonSteel
2023 Ford Bronco Wildtrak
I have seen that posted a few times (XR's have thicker tube walls), but could never find an objective data source to confirm it.
CarbonSteel
You are very much allowed to say it and if it works for you, fantastic--it doesn't work for me and I already said that I would agree to disagree so we can just let it go.
ssrgeoff
PNW
Okay, so same outside diameter but thicker wall. Thats definitely a plus...
CarbonSteel
IF it's true. I tried to find some data from FCA or Dana to confirm it and never found anything.
Jtphoto
Thunder Bay ON
It is in fact the 392/Mojave housing. It also changes the GVW from 5800lbs to 6100lbs. The FAD is also heavier the MC RubiconFAD skid does not fit on it. You should be able to find those specs looking up the 392 or Mojave.
MilkSteak
Palm Springs, CA
2022 JLUR XR
I'm glad I read this, I was planning on buying that Skid first since the FAD is so vulnerable. I will have to ask them if the 392 Skid could possibly work
Jtphoto
Thunder Bay ON
Ask me how I know. I have the Regular Rubicon MC Fad skid in the shop that needs a new home. Apparently MC won’t have one to fit the XR until August.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
A larger diameter with the same thickness would be considerably stronger than the same diameter and a couple mm thicker wall. They chose the latter so that the same bracketry could be used, which is more economical for production.
ssrgeoff
PNW
Yeah that makes sense from a production standpoint. The fact that it is thicker, even if its millimeters is still better than your standard.. but slightly. I am sure most who buy this package aren't solely paying the 4k upcharge for the axle alone but for all the other goodies. Otherwise, as mentioned above there is much better options. Do you know if this "HD" axle is also in the EcoDiesel or is that your standard Rubicon?
hoag4147
Colleyville, TX
2022 JLUR XR
Diesel has same as gas Rubicon. The XR is same as 392 with exception of FAD. Not only thicker wall but iron knuckles.
GATORB8
CLT NC
21 JLURe
Those Beadlock Capable wheels are also 4.4” backspace 12mm Offset.
A +12mm offset on a 8" wheel is 4.97" backspace, not 4.4". 4.4 BS would be -3mm offset on an 8" wheel.
I think I saw on here where someone measured and came up with ~5" BS.
Jtphoto
Thunder Bay ON
I did a web search a few days ago and those were the figures that came up on a sales site for the Mopar Black and silver Beadlock capable wheel that is suppose to be the same, the figures did not come from a forum post so I expected them to be somewhat accurate. That being said who knows how many configurations they may have for these wheels as the also have them on the TRX. At any rate, anything Between 4.5” and 5” BS is good.
