unsavory
- Jimmy
- Sep 17, 2018
- California
- 2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
No, you cannot drive your Jeep in Part Time 4H, even with LSD. LSD doesn't affect your ability to drive in 4WD on dry pavement. The danger comes from the front and rear tires rotating at different speeds during a turn, which your transfer case will not be able to do while it is in 4WD.2 more questions: 1. Did you tint the front driver/passenger windows? 2. Willys is LSD; therefore, can I drive it in 4H as much as I want? The Rubicon locks so I understand you can't dirve with wheels locked all the time.
The exception to those rule is if you have the optional 4WD Full Time system, which shows you to select between 4WD Full Time and 4WD Part Time. It's safe to use 4WD Full Time on dry pavement.
