Old Jeeper
Take Away: What is IMPORTANT is the Contact Patch!Interesting comments but I am talking about stock 35s on the XR package. No tire change or size change. New Jeep.
You want a full-width contact patch. For several reasons. Safety, traction, braking, and life of the tire. If the outer edges of the tire are not touching pavement then you will prematurely wear out the tire in the center of the tread, if your outer edges wear faster then you are under-inflated.
Your most comfortable ride will come from a full contact patch. If you are off-road in sand, dirt, or rocks you want to max the size of your contact patch.
Look at the design profile of a top off-road tire, like what I run, BFG KM2. 16 in psi in the city give me a FULL-WIDTH contact patch. I run off-road 3-5 psi. My width stays the same but my tire increases the contact patch by getting longer not wider.
Here is a pic of my jeep on 37x1250x17 GY MTRs. That is another purpose-built tire for serious off-roading and in the rocks. I am running about 5-7 psi on GYs. Note the front right tire is bulged out but not contacting the rocks that come from strong sidewalls that support the tire and does not let the sidewall collapse and roll on the rocks.
Now look at the right rear, you get a good idea of how long the tire becomes which increases the contact patch, this is really critical in serious rock trails.
I am running 35s on my 23-JLR, GY Duratrac and I get full contact patch at 32 and they ride like a dream...
