Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
Springs coming loose is less of an issue with a spacer as you effectively lowered the upper coil bucket by whatever height spacer you're running. On an XR there is enough bump stop to run metalcloak rocksport shocks and even with the full 30" extended length utilizing 12"+ of travel the coils were still tight with a 2.5" spacer. For that kind of downtravel you will need longer swaybar end links. With that amount of lift you'll want at least adjustable lcas up front to fix the caster. With just those simple mods you can wheel the hell out of an XR on 37's. If you really want it to handle great at that height I'd recommend front control arm drop brackets, but you could do those instead of adjustable lcas and still be under $1k into the suspension with a rig that will ride better than almost any kit that doesn't lower the control arm mounts or isn't long arm in my experience.Maybe, the 2-3" I think, factory isn't much over 6-7 inch travel. Fox will give 9-10 odd from memory.
You need to look at Collapsed and extended length. Not the marketing drivel. You can work it out by measuring eye to eye and subtracting bump stop space for Collapsed. Then find a shock that goes a little less than that, with as much stroke as you can find. You will probably max out around 9-10 inches stroke.
You will need to check cables when drooped so you don't tear shit up... And see if your springs come loose.. Which they probably will (spacers are a cheap fix) .. You will get into a loop of upgrades if you don't go in with a spec to build to imo.
