Retired Jeeper
I have a JLURXR arriving soon. I want to run 37's off-road with the least lift necessary. I'm old and can't scramble into lifted Jeeps like I once could - ha! Given that a standard JLUR can run 37's with 2-2.5" lift (and appropriate bump stops) and the XR comes with a 1.5" lift, my "plan" is to add 1" spacers in front, 1/2" spacers in the rear, and put on some Bilstein 5160's for a 2-3" lift. I have some stackable 1/2" bump stop extensions to use as needed. Does this seem doable? Anyone running this kind of set-up? Do I need longer sway bar links? Constructive criticism and ideas from others who have explored this approach are welcomed. I used the following chart to determine which Bilsteins to consider. Thanks!
