LeoTheDragon
- Sep 18, 2018
- In my Jeep
- 2019 JLUR
$250 picked up, $300 shipped. Located in Northern NV.
Missing the following (per the 'Call Out' column on the instruction sheet) :
5 - Missing one yellow washer**
6 - Had to reuse these so you'll have to get them from either the hardware store or the service dept. at the dealership may have them if you insist on this specific bolt. They are M8x1.25x50mm bolts.
7 - Missing one pink washer**
8 - Not missing, plugs already installed
10 - already installed
11/12 - one and done items, just find some cardboard and twine or string and you're set.
**I have some metal retaining washers I can try to find and include if they are the right size. They will be just fine as an alternative to the plastic ones. I remember breaking the two plastic ones with my Uber strong fingers when installing and had one of each missing the entire time while running this kit (about 2 years) with no issue.
