Wrangler sport JL can it fit 285/70/17 -12 fuel zaphyr?
Youjam
Yusuf
Kingdom of Bahrain
Wrangler jlu sport
Hey all
This is my first post as I'm a new jl owner from the middle east (2018 jlu sport stock metallic granite).
Im planning to change the stock wheels from 245/75r17 to 285/70r17 or 285/75r17 with fuel zaphyr bronze 17/9 -12. Would it be OK with that offset? Or it would be poked alot and look bad?
And If any has 33s with -12 stock suspension on a sport or sahara please share some photos
Thanks in advance
Texcat101
Jack
2020 Rubicon Recon, Granite, 2.0L; 2018 Grand Cherokee Summit (Hers); 1985 4rnr 4.3/700r4, 4:88, MS 2 ECM,
Semi-Retired
Hey all
Thanks in advance
I like the wider stance, always preferred the aggressive look. There should not be any problem with fit or clearance. Your choice in tire size is very close to the 33x12.50 that came on my stock Rubicon, which is able to accommodate 35’s. I would do a google image search for that combination.. I bet you find helpful images.
blnewt
New Mexico
Just ask @cosine he knows!
285/70 will be better than the 285/75 unless you plan to lift it a bit. If you can locate a Rubicon suspension swap in your country that will net enough lift to fit the 34" tall 285/75s.
Those -12s will poke a fair amount but also work better if you plan to lift it (they will allow more room to the inside).
Here's a good site for trying new tire/wheel setups, it includes a visual tool as well.
https://www.wheel-size.com/calc/
Youjam
Youjam
Yusuf
Kingdom of Bahrain
Wrangler jlu sport
Thanks a lot bro much appreciated
Youjam
Youjam
Yusuf
Kingdom of Bahrain
Wrangler jlu sport
Lifting is a problem to me tbh.. So I'll stick to the 285/70 as we have only 1 jeep agent monopolizing the market and charges around USD 2950 for an all in all Mopar 2 inch lift (they don't alow any other kind of lifts and any lift outside the agent or u loose the warranty on alot of things).
But thanks anyways for the thoughts
geem03
Gary
New Brunswick Canada
2019 Jeep Wrangler Sport
RN/ Firefighter
First pic with stock wheels
Jeep Wrangler JL Wrangler sport JL can it fit 285/70/17 -12 fuel zaphyr? 20191016_084348
Second pic with 285/70/17 stock suspension (really 33's)
Jeep Wrangler JL Wrangler sport JL can it fit 285/70/17 -12 fuel zaphyr? 20191028_113202
Third pic with 285/70/17 with rubi take off suspension
Jeep Wrangler JL Wrangler sport JL can it fit 285/70/17 -12 fuel zaphyr? 20200618_084806
Front view
Jeep Wrangler JL Wrangler sport JL can it fit 285/70/17 -12 fuel zaphyr? 20200116_074344
Youjam
Youjam
Yusuf
Kingdom of Bahrain
Wrangler jlu sport
Front view
Thanks alot for sharing but I guess ur offset is in the (+). Iv ordered the fuel zephyr 17/9 with an offset of -12 and I think that it will poke alot.
Will never know till I fix it so let's see
geem03
Gary
RN/ Firefighter
Not sure if the offset....
