Wrangler Rubicon JLU 3.6 engine pre-detonation
Hau82
Alfredo
San Diego
2018 Jeep Wrangler JL Rubicon unlimited
hi guys,
Only have 2,200 miles and about a month ago I started hearing some knocking/pinging noise in my engine particularly between 2nd and 3rd gear at about 2k to 2.8k rpms more noticeable when going uphill or from a stop when taking off in 2nd gear (auto tranny) , I blamed the fuel so I tried a new brand and higher octane to see if the sound goes away. So after a month of testing, the noise has become more noticeable and I'm starting to worry about something getting broken. Does anyone have had this problem and got it solved?
JeepCares
Auburn Hills, MI
JL
hi guys,
Hi Hau82,
We are terribly sorry to hear that you have this concern with your new JL. Have you brought this to the attention of your dealer? Please send us a PM with your VIN and mileage if you are in need of additional assistance.
Darlene
Jeep Social Care Specialist
intentsrig
JLU Sporticon
hi guys,
Yeah I have heard the same. Similar to the sound my 3.8 made and that was considered ā€œnormalā€ for the 3.8 according to the dealer
Hau82
Hau82
Alfredo
San Diego
So far this is what I have done,
I plugged my obd2 scanner to my Jl port and got a green light (everything good), I pressed the red button of my scanner to ā€œeraseā€ codes (even dough there are no codes) this will erase all the sensors data stored in the ecu forcing it to relearn. So far everything seems back to normal, still need to drive a few more miles to complete the ecu relearn process, a soon as I get the obd2 green light Iā€™ll post update info.
Ruby Jack
CT
'18 JLUR
I wouldn't try doing anything yourself. Just take it to the dealership and let them handle it. You have 3 (or was it 5?) years of powertrain warranty, might as well make use of it.
Rockmaninoff
Melbourne, Australia
sophistijeep.blogspot.com
MY2014 JKU Overland (RHD) A/T, Mercedes E-class MY2017
hi guys,
In the JK manual I remember it saying that some light pinging at low rpms is normal.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Have you had an oil change since receiving you jeep? I have seen others who used an aftermarket oil filter reporting pinging/knocking afterwards.
That One Guy
Ryan
2004 Honda Accord coupe, V6 6-speed manual; ordered 2018 JL Sport 6MT with A/C and anti-spin. D status.
Have you tried using midgrade or premium fuel?
DanW
My 3.8 in my JK pings once in awhile. When it starts, I'll give it a couple Italian tune-ups and run a tank or two of V-power through it and it clears up for 5 or 6 thousand miles. If I run 89 octane all the time it won't do it, but I don't want to spend that money all the time. Worn spark plugs have also contributed, so I change them out about every 40k, and that helps.
I'm sure slight pinging is normal, but I don't like it. My JL isn't doing it, so far, but when it does, it will get The Italian Job and a dose of V-power.
I also ALWAYS run Top Tier rated gasoline, in both Jeeps. My JK will ping much more after a few tanks of cheap gas that is not Top Tier rated.
It sounds like OP found a solution that's cheap and works. Thanks for sharing it!
Biscuit
Northeast Ohio
2018 JLU Sport
Top Tier is, IMO, mostly a marketing gimick. Even opinions of knowledgeable folks are mixed.
Gas brands can participate and get a TOP TIER license if they meet certain standards, which includes performance tests for intake valve and combustion chamber deposits, fuel injector fouling, and intake valve sticking. Additive manufacturers pay for the testing, the cost of which varies from year to year, while gasoline companies pay an annual fee based on the number of stations it operates to participate in the program. In short, Top Tier's first priority is to generate revenue from testing costs and licensing fees.
OTOH, nowdays you'd have to search pretty hard to find gas that isn't so licensed - even the so-called "cheap" fuel retailers. Furthermore, all fuel producers share pipelines, distribution terminals and transportation contractors, so it's all the same gas regardless of brand, although additive packages may vary slightly. But then again, practically all of those fuel producers get their additives from a single supplier.
mwilk012
Service
7/11 is still willing to sell you low quality gas if that's what you're into. They're pretty widespread.
DanW
Talk to someone who works at a fuel distribution center where they handle the additives. They'll tell you that Top Tier gas gets better ad pacs and that they are tested to ensure they meet the standard. More and more gasoline sellers are getting the certification because more and more customers are looking for it. Around my area, all the fuel comes from the same distribution center. The additive packages are what differentiates them. The bigger brands, such as Shell and Mobil, have thier own proprietary add pac. Most of the others go with packages offered by the distributor, which range from the basic one that meets the minimum EPA standard, and various levels of upgrade, including a level that is certified as meeting Top Tier. In this case, it is simply more additive per set volume of gasoline, or less, depending on what the customer wants.
Run what you want. I'm not putting cheap crap that meets the minimum standard for detergent in my $50k Jeep. My JK 3.8 is sensitive to deposit build up and will ping and knock like crazy after only 3 or 4 tanks of the stuff, getting progressively worse. I've learned that over many, many miles with it. It takes MUCH longer for the build up and pinging to occur on Top Tier gas, which for me, 90% of the time is Shell.
DanW
So will Kroger and Speedway and countless independent stations.
islandtees
gary
florida
2018 rubicon jl
The only name brand by me is Sunoco. I would think they use a better pac?
Jeepsterfreak
Honda, Future JLU
Sams Club also. Costco is now top tier. Thinking about switching my membership just for the gas. Philips 66 is dominant in my area. Unfortunately no Chevron stations near me.
