WRANGLER JL WILL START & RUN WITH BATTERY REMOVED
mgroeger
Hurricane, UT
2018 JLUR, 2020 Acura RDX A-Spec
On a JL/JLU .... To kill power from the Main battery and the ESS battery:
Twice I've had to disconnect the three negative battery terminals. Each time terminal #2 (from the pic) sparks like heck when you touch it back to the bolt to thread it on. I can here a clicking noise coming from the black box right next to it.
Has anyone experienced that?
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
@mgroeger
I do not have a JL yet.
Normal to see this ....... is what I can tell per posts here, a YouTube video I saw and a tech I asked at the stealership a couple of weeks ago.
FatBoy01
NY
Retired @ 55
Just wanted to clarify some info I posted earlier in this thread. I had placed an incorrect pic showing terminals in the post as N1 and N2 which they weren't.
Yes, the negatives are both common but the positives go to two different posts (N1 & N2) in the power distribution center. There is module / ESS relay that controls when to use the ESS and when not to use. N1-Main battery, N-2 ESS battery.
Important to know: You can have a fully charged Main battery and if the ESS battery is either dead or disconnected, the JL will not start, even though the main battery is fully charged. On the other hand, if the main battery is missing or dead the ESS battery can start the JL/JLU.
If you wanted to isolate the positive side, disconnect N1 & N2 in the power distribution box.
BillyHW
CAN
Important to know: The ESS battery is what actually starts the JL/JLU, not the main battery! You can have a fully charged Main battery and if the ESS battery is either dead or disconnected, the JL will not start, even though the main battery is fully charged.
That doesn't sound right at all.
FatBoy01
NY
Retired @ 55
Daaaah, l must be making it up then. How about you come up with something different Einstein.
BillyHW
CAN
Does it really make any sense that in places that get cold winters they'd use a battery with ~200 CCAs to start a vehicle instead of a battery with ~700+ CCAs?
FatBoy01
NY
Retired @ 55
My wording was incorrect. I edited / reworded that post so hopefully it is conveying what I meant to convey.
After I reread my post I see why you questioned it..
rizej
Jared
Denver, CO
What order are you reconnecting the battery terminals back together? Maybe a different order would stop the sparking
mgroeger
Hurricane, UT
Another member confirmed this to be "normal". He had seen a YouTube video and spoke with a tech at the dealership and they saw the same thing.
NFRs2000NYC
NYC/NJ
2014 Jeep Wrangler Unlimited Rubicon
So does the Jl then have a dual battery system from the factory? If the main one is killed the smaller one with start the jeep, or is the issue the fact that there is no isolator, so if an accessory is draining the juice, it wont stop at the main battery, and it will drain them both?
BillyHW
CAN
Kind of useless if you can't start the car if the small battery is drained for some reason. This boggles the mind.
JIMBOX
JAMES
FERNLEY NV
2018 HELLAYELLA JLU SAHARA/2016 "STINGER YELLOW" RAM
Well, the owners manual shows using a jumper cable set-up, as we have for over 85 years and connecting connectors to the MAIN PRIMARY battery +/- and making no other adjustments/conns/disconns--
Just follow the safety conditions with ign sw/jumper cable sequence--start booster car/start jeep/disconnect (follow sequence)/drive jeep away--go home tell wife because of the trouble, you have to have a HEMI/LS swap as soon as possible !
Whatever
JIMBO
BillyHW
CAN
Whatever
JIMBO
Yeah, I checked the manual too and the jumpstart procedure appears to be the same as every other car ever made since I was born at least.
Spotscrib
Alfred
2018 Jeep Wrangler Rubicon JL
How long before you lost complete power I just did the same and I still have power
mgroeger
Hurricane, UT
After disconnecting the THREE negative battery terminals I lost power immediately.
Superchips TrailDash 3
