Wrangler JL 3.6L Tuning Now Available from Superchips
Superchips JL
Summit Sponsor (Level 3)
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
2018 JL 3.6L WRANGLER TUNING IS NOW AVAILABLE ON FLASHPAQ AND TRAILDASH2
Click here for full details and to shop today
Best to Market, Pre-loaded Performance Programming Now Available for 2018 JL Wrangler
Superchips Flashpaq & TrailDash2
Demand for performance programming, covering the 2018 JL Wrangler, has been off the charts. Today, Superchips is thrilled to offer JL Wrangler pre-loaded performance programming for the Flashpaq for Jeep (part no 3876-JL) & TrailDash2 (part no 42051-JL)! Our team has fielded many calls, emails, and messages via social media asking when a solution would be brought to market. Today is the day! You can shop now for your pre-loaded performance programming right now.
An extensive set of custom features including tire/gear calibration options, auto start/stop management and daytime running light settings accompany power gains of up to 29 HP & 37 lb-ft TQ. Superchips will continue to offer a best-in-class PCM swap process for the 2018 JL Wrangler and a jumper module will be required, and included, with both the Flashpaq & TrailDash2. Flashpaq and TrailDash2 offer features and power unlike anything on the market today. It is important that you make you follow the unique steps required to tune this exciting vehicle. There is tremendous demand for JL Wrangler, and as the pioneer’s in the performance programming for Jeep, we could not be happier to now offer this coverage. Shop today!
Flashpaq Features:
Tuning
Octane HP TQ
Performance 93 + 29 HP & 37 lb-ft
Performance 91 + 25HP & 29 lb-ft
Performance 87 + 17HP & 18 lb-ft
Tune Options
Available Range
Gear ☒ 2.73 – 5.38
Tire Size ☒ 25” – 41”
Transfer Case ☒ 2.72 – 5.00
Adjustable Rev Limiter ☒ Stock / Superchips Value / +256 / +258
Speed Limiter Control ☒ Stock / Raised
Auto Stop-Start ☒ On / Off
Quick Options
Engine Idle Up
☒ 700 – 2000 RPM
Sway Bar Unlock ☒ Unlock / Exit
Line Lock ☒ Lock and Hold / Exit
Rock Lock ☒ Lock and Hold / Exit
Auto Park Disable ☒ None
TPMS Warning Threshold ☒ 22-56psi
TPMS On/Off ☒ Enable / Disable
Daytime Running Lights ☒ Always On / Selectable / No DRL
DRL Location ☒ No Running / High / Low / Turn / Fog / Fender
DRL Dropout ☒ Enable / Disable
Fog Light Dropout ☒ Enable / Disable
Halo Lights ☒ Enable / Disable
One Touch Lane Change ☒ Enable / Disable
Seat Belt Minder ☒ Enable / Disable
Travel Link Weather Warning ☒ Enable / Disable
Splash Screen ☒ Sport / Sahara / Rubicon
Standard / LED Lights ☒ Front Turn / Tail Lights / 3rd Brake Light
Auto Stop/Start (ESS) ☒ Enable / Disable
Auxiliary Switches ☒ Enable / Disable
Towing Package ☒ Enable / Disable
Blind Spot Detection ☒ Enable / Disable
Sway Bar System ☒ Enable / Disable
Cargo Camera ☒ Enable / Disable
Backup Camera ☒ Enable / Disable
Electronic Steering Pump ☒ Enable / Disable
Axle Lockers ☒ Rear / Front & Rear (Enable / Disable)
Factory Fog Lights ☒ Enable / Disable
Superchips TrailDash2 Features:
Tuning
Octane HP TQ
Performance 93 +29 HP 37 lb-ft
Performance 91 +25HP 29 lb-ft
Performance 87 +17HP 18 lb-ft
Options
Available Range
Tire Size ☒ 20-44 in
Traction Control ☒ Off/On
Auto Start/Stop ☒ Off/On
Running Lights ☒ High/Low/Turn/Fog/Euro/None
TPMS Toggle ☒ On/Off
TPMS Adjust ☒ 22-64 psi
Running Lights with Turn Signals ☒ On/Off
Axle Ratio ☒ 2.0-10.0
Accessory Delay ☒ 0 seconds – 10 minutes
Lamp Delay ☒ 0 seconds – 10 minutes
Horn Chirp Toggle ☒ Off/On
One Touch Lane Change Toggle ☒ Off/On
Fog Lamps with High Beams ☒ On/Off
Transfer Case Lo ☒ 1.0-15.0
Lock differentials ☒ On/Off
Lamp Flash Toggle ☒ On/Off
Rev Limiter ☒ -500 +500
Speed Limiter ☒ 97 – 140
Due to overwhelming demand - please be sure to leverage our online chat support and call us during business hours between 8 AM and 5 PM EDT. Thanks for your support.
Updated with dyno chart:
Aggie
Texas A&M
2018 JLUR Mojito!
Octane HP TQ
Nice to see a tuning solution for the JL now. Are these figures for the 3.6L Pentastar? Or the 2.0L turbo?
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
  • Thread starter
  • Thread Starter
  • #3
This is for the 3.6L. The 2.0L is in development. Thanks!
Fire Burns
Fire
CA
2018 JLUR 3.6; 2006 Chrysler 300c SRT-8
Would love to see actual dynographs side-by-side with a stock Wrangler with only changes but the tune. Got those?
Superwinch
VA
2014 Rubicon, Yamaha Raptor 660
Solid power gains considering it's an NA engine. Plus all the additional features it comes with. I'm sure the turbo will see even more power delta from the tune.
Fire Burns
Fire
CA
Also, for us here in California:
Do you know if a Flashpaq of TrailDash2 equipped JL will be able to pass smog?
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
  • Thread starter
  • Thread Starter
  • #9
We are currently testing with CARB and have an extensive application in with CARB. At this time, this product is not for use or sale on pollution controlled vehicles in the state of CA. We will keep you updated.
Fire Burns
Fire
CA
Do you think it would pass Smog if the stock tune is installed for the test, or will the modification to the chip set off an alarm? I ask for purely academic reasons and would never attempt this myself. Just curious. ;)
RELBUS
Chicago
97 TJ , 18 JLUR
Of course it would pass smog, stock tune is stock tune.
Fire Burns
Fire
CA
I get that it would pass particulate and carbon monoxide tests, but for those unfamiliar with California Air Review Board (CARB) policy, there is also a visual inspection and your vehicle is plugged into the OBED II sensor as well. So I guess the real question is (and I doubt for legal purposes that they will answer) is if the modified chip, even in stock tune, will set off any alarm bells on the OBED II scan, because clearly it would pass the other parts of the test.
Commiefornia is real folks...
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
  • Thread starter
  • Thread Starter
  • #13
We develop all of our tuning and products to work in concert with on-board emissions systems and not take anything out of the standards when it comes to emissions. All that said, we typically find ourselves in a logjam to get things over the line with testing and approval with CARB. While it is oftentimes painful to wait and limit sales to CA, it is the best decision for the long-term interest of our business. Everything we bring to market goes through the process w/ CARB. As soon as we get the green light (an EO) we will be very sure to let everyone know. From there you can have all the documentation you need when/if asked for your smog check.
SONofHELGI
Michael
Enterprise, Alabama
2018 Jeep Wrangler JL Rubicon
Something that sounds technical, but it's not.
"Remember, there are no stupid questions, just stupid people."
Are you working on an economy tune at some point for those of us wanting to get a little better MPG?
If I got a traildash now, do I have to pay for these tune upgrades?
I had your traildash in my JKUR 10A and loved it! Thanks for you time and
baysta
UT
N/A
Do you expect this tune to work with the upcoming 3.6L + BSG? Or would that require a different tune given the additional system?
Next Venture Motorsports
