Jebiruph
Some early JLs are having issues with corrosion on the aluminum body panels and door hinges. You will want to pay close attention to that.
That was a hot topic in 2018 - 2019Yeah... That is exactly what's happening (Most of the time). If you pull off a failed sensor, you can tip it and see oil inside of it.
That's only one possible cause to the same light though. Many people are going through many different causes to the same symptom. This is meant to help prevent the majority from needing to wait weeks for a rear axle replacement.
@mgroeger - Do you still have pictures of the sensor off of Fat Ninja? Pic of the oil inside the sensor?
Thank you.
Bubbling paint on door hinges is still happening to 2023 JLs.Some early JLs are having issues with corrosion on the aluminum body panels and door hinges. You will want to pay close attention to that.
