Jamrock
Nobody.Who the heck says adding lockers is a bad thing on any 4x4 unit be it truck, jeep or whatever?
I installed Rubicon axels on my 2019 Sport-S and wired this harness to anOkay...
So I guess you connect one end of these to the axle. I would expect you to connect the other end to some kind of button on the Jeep's dashboard. How does that work?
What power supply does it use? The third party aux switches attach to the battery and then power the devices to which they are connected. How does this work?
Cool. Thanks.I installed Rubicon axels on my 2019 Sport-S and wired this harness to anS-tech switch but any switch system will work
My Sport came with a Dana 44 LSD rear. I've had no problems with rocks or sand...yet.I'm seriously considering a JL which will be a daily driver that will also get some off-road and even off trail use in desert/mtn type areas, like Moab.
I was thinking of something like an ARB or Eaton E-lock in the rear and a Torq Lock in the front to give it (almost) Rubicon off road capability. Is that set up worth it or is the Rubi still a better option? Thanks!
- Take off wheels/tires: $1200 (w/ KO2's)I'm seriously considering a JL which will be a daily driver that will also get some off-road and even off trail use in desert/mtn type areas, like Moab.
Honestly if you stick to the trails that are 6 and below in Moab, you don't need a locker and you don't need a lift, though... it would be nice (you will scrape quite a bit at stock JL height).I'm not looking to lift or go over 33" tires. Other than the lockers/LSD and maybe additional skid plates, it'll remain stock. Heck, my thinking is that a pure stock Wrangler Sport is pretty darn capable off road. I'm just looking to up its game somewhat. Having driven a lot of off road miles with open diffs, the thought of having power to all four wheels is very appealing.
Now add the price of the 33’s that came on the rubicon, skid plates you don’t have, 4-1 tcase you’re lacking, sway bar disconnects, rocker protection, and higher clearance fenders when you do want to go to 35’s and you have already spent that $7k easy. You still have narrower and weaker axles, your locker isn’t selectable and you only have 1, your disconnects are manual, and your resale value is still thousands less than the rubicon. If you want to ”hang with the big dogs” either buy the rubicon out the gate, or at least upgrade your axles.As I understand it a lunchbox locker like Aussie would be fine if the front D30, the rear however could quite possibly have spline issues due to the number of splines and the material composit. I have a Sport S and bought rubicon suspension takeoff parts added the longer lower control arms (LCA) to correct for Castor geometry. This with 33” tires and I will probably be a little taller than a Rubicon. 35” may be possible but will probably rub. So my JL80 is $37,000 vs a rubi $44,300.
$37,000.00 JL80
$101.00 LCA’s with shipping
$75 Rubi shocks & Springs
$400 lunchbox locker
My math says I run with the big dogs for a whole lot less
First, drive it, wheel it for 6 months to a year. Now what do I need vs. what do I want.
My list. In order of install.
Level up kit or 1-2 inch spacer lift (80-350$)
Longer better shocks. (200-500$)
Front Sway bar disconnect. (90-375)
Front ARB. (1300-1500$)
Tires 33’s. (600-1200$)
F&R bumpers. (800-2200$)
Winch. (400-1800$)
I’m keeping the stock rear LSD. (Previous experience with a Detroit in the rear and NO sway bars front or rear on a YJ-just not that crazy or hardcore anymore)
Shocks—better to help with the “little lift” or leveling option.
ARB- best mod ever to my last YJ. (Front only)
I’ll wait on tires as mine has 32’s presently.
Bumpers?— some sort of front end skid protection would be an incorporated preference.
Winch? old school receiver mount front or rear. 5klb w/ a pulley and synthetic rope.
So- the cost. $3800 to “shouldaboughtarubicon”.
Now-If they’d toss in a 3 speed transfer case (2.5 and 5.0), the 3.0 Diesel in a 2 door and a PTO. 4 inch lift and 37’s and I’ll start the second mortgage Super RUBICON paperwork.
My wheel’n days are not over. My ability to crawl under and around a 4x4 and walk 25 miles to get help is being screwed with by father-time.
My list, my money.
Congrats on your purchase. No matter what, fun is guaranteed!Just returned from ordering the Sport at the local Jeep dealership. It'll have the LSD rear and the 80th Anniversary pkg. I won't be lifting or adding big tires, as it comes with 32s and I won't go bigger than 33s when they need replacing. Still interested in a front locker like an ARB or OX. And the sway bar disconnect, too. Might add a skid plate under the oil pan/trans.
I appreciate all the good advice everyone has offered in this thread.
Thanks, guys.
Congrats!! Yes, get the sway bar disconnects. I will shortly post my experience with APEX ones I had mentioned a few days back on this thread.Just returned from ordering the Sport at the local Jeep dealership. It'll have the LSD rear and the 80th Anniversary pkg. I won't be lifting or adding big tires, as it comes with 32s and I won't go bigger than 33s when they need replacing. Still interested in a front locker like an ARB or OX. And the sway bar disconnect, too. Might add a skid plate under the oil pan/trans.
Thanks, guys.
