Jeep Dude
My ride is a 2019 Wrangler Rubicon Unlimited, on KO2 37's, with a Metalcloak 2.5 lift, and a few other goodies like full metal skid plate(over 100 pounds) etc.
It is my daily driver, so I do drive on more dangerous, 2-way roads, where traffic speeds are about 65mph, and passing power is important around the 18-wheelers.
If you are driving an anemic car, with subpar passing power over 65mph, it can be a butt puckering experience. I also love rock crawling on the weekends up in the mountains, and driving up extreme vertical incline gravel roads, sand dunes, etc.
Now to the question, that has been putting me off from re-gearing for the longest of time. I have read many posts on this forum, about which regear ratio is the best, and ultimately it seems to boil down to personal preference, so I don't want this discussion to turn into a , my 4.88 is better than your 5.13 and vice versa type of thing.
I want this to be a comparison of various re-gearing ratios, including stock, with real world acceleration observations from owners, on WOT, kick-down passing power with the 8-speed auto, 37inch and larger tires, at speeds over 65-70mph, and preferably with the 3.6L (unless the 2.0L owners are experiencing and observing what it is that I describe here)
I must say that I'm a bit surprised, that I have not read more discussions, on the 8 speed automatics ability or disability, with a significant regear, to be able to downshift(kick-down), from 8th speed to 4th speed, or basically a low enough gear, that will allow the Pentastar to hit REDLINE, while attempting a WOT pass around a huge truck at speeds over 65-70mph.
I have heard and even seen on youtube, owners with 5.13 gears, and I THINK even with 4.88's on the 8-speed, with 37 inch tires, and the 3.6L, completely lose its ability, to downshift to a proper gear, that would provide optimum FULL POWER for passing, even when attempting to manually downshift it. To reiterate, with stock 4.10 gearing, on an exact same setup, the auto 8-speed will downshift at WOT, regardless if doing over 65-70mph, to a low enough gear, that will allow the RPM's to stay in the 5000-6000rpm zone while passing, and achieving full power while WOT.
With higher re-gearing, at least with the 5.13's, this does not seem to be the case. It will NOT downshift to an efficient enough gear, to allow for maximum passing power at those aforementioned speeds. This to me is a deal breaker, and quite disconcerting.
I noticed that Jeep added 4.56 gears on the Xtreme Recon package, which makes me ask two questions in regards to this choice. Did Jeep reprogram the auto transmission (glitch), to allow for good power WOT downshifts at higher highway speed passes? Or is this the "sweet spot" gear ratio afterall, for those who fit the criteria i basically humbly tried to describe above? Will adding 37 inch tires, to the xtreme recon package, with the 3.56 gears, and 8-speed auto transmission, still allow for identical type of downshifts, as with stock 4.10 Rubicon gears, on 37inch and larger tires?
I hope my question is clear enough to understand, and the dilemma I'm having about which re-gear project to do in the future, if any at all. It's not like I'm dissatisfied with the 4.10, nor am I desperate to replace it, not by a stretch of the imagination. Clearly, my perfectionist side seeks a higher numerical gear ratio, for the obvious reasons, that need no explaining.
