Willy's Commando
2013 JK Sport, 2009 Challenger R/T, 2019 Dodge Hellcat, 2019 JLU Rubicon
Tera Fkex ST1 Lift, 1.5 spring spacers/ bigger bumps stop. Rock Hard Aluminum freedom series bumper, RH sway bar motor skid plate, RH front axle motor skid plate. and artic spare tire delete kit. Lost about 200lbs wish my diet work as good. I will through my spare tire in the back if i doing any 8 plus trails. Next week will install shock extensions, longer sway bar links, new rock sliders and ridged amber radiance pods in the fog light holes.
Tuesday she goes to get xpel wrap and ceramic coat/wax.
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend 79B7C414-9F85-490C-9FD4-9D3496B7FE38
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend 940E942D-37E5-4132-BA01-356AD1BC33B6
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend 479BCA54-DD9A-4E53-9188-35DFA07392D9
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend 55C43F7F-F9B4-48A5-B14B-32E96754CF4D
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend 8593FC74-C637-4C50-8573-6CE554726E0D
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend B25094F6-2D6B-4B84-95CC-2D00AC9E3B32
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend 1EE9D5FA-BD5C-4762-AC10-77CC4A753E61
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend 6F7676DB-7559-4E16-ADA8-42F65BC20160
0II392II0
Washington
JLURH
Right to it, :captain:. I've come to really like it in black, looks great. I'll be Following this thread, it will be interesting to watch your build. Looking like another 2-7 day until mine and I would still love to see a picture of the specs on the back of the rims if you wouldn't mind.
rickinAZ
Phoenix
I read "gave her some air" and looked for modifications to give your 392 better breathing, but didn't see any. Did you mean that it was sitting higher with the lift/spacers?
Willy's Commando
Willy's Commando
Oh yeah I forgot to post that pictue, it gets enough of that air LOL. Installed ARB air compresso.
Jeep Wrangler JL Worked on the 392 diet, gave her some air and made him a little taller this weekend F69C03E0-5986-4B39-BF5B-AD12CD92475E
BCMgunner
Eli
392 on 37” KO2s
Awesome build! Will follow!
Two questions.
1) You did a full 2” lift up front while 1.5” in the back. Are you only installing shock extensions only in the front or front and back? Teraflex says shock extensions are only for 2-2.5” lifts. What brand are you going with?
2) Does the 392 need a front axle motor skid plate even though the 392 has no FAD? I’m guessing your concern is because the cast iron housing is still present, it is still a weak point on the front axle?
Thanks and sorry I’m advance if I copy some of your mods👍
Willy's Commando
Willy's Commando
Two questions.
No problem.
1. once the spacers went on it extended the stock Fox shocks a little to much for comfort, No problem if you are only going to drive on the street. That Fox shock is almost fully extended it’s only good for a 2 inch lift. i have a second home in Colorado and will be doing alot of off roading leave less 2 week don’t want to blow out those shocks so I’m putting Rubicon Express JL shock extensions
This is only a temporary fix until this fall/winter when I put. Full born lift kit with new shocks.
if you do any off-roading with those spacers and you ether put on new shocks or extend the stock shocks it could get ugly. I don’t plan on doing any hard wheeling this summer ( 6 trail rattling or less until I have a new lift). Once I get to Colorado and get off road I’ll keep you posted.
https://rubiconexpress.com/Suspension/Shock-Absorber-Extension.aspx?t_c=1&t_s=90&t_pt=3954
2. Rockhard 4x4 sent me the axle motor skid plate at no charge, (bought a ton of stuff from them and they hooked me up) so why not install it fitted, might be.weak point. i called them today about the aluminum rear bumper which I plan on installing I already have it on my 2019 Rubi. for more weight reduction with the bog ass muffler concerned about it fitting they will get back with me on that. But also said they are almost ready to release full aluminum skid plate production for the 392 in another month which I will purchase as soon as available.
https://www.rockhard4x4.com/
dietch
Davis
Greensboro
2018 Jeep JL Sport S
Is it me or do your wheels look weirdly small in those 37's? I know its a 17in wheel but in the first pic it looks like a 15in.
It may just be the angle of the picture.
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
Based on your title, I thought there was some sort of Jeep sex change mod going on :LOL:
TJJL19
TJ
2019 Jeep Unlimited Sport
I think I've been in Law Enforcement too Long, so you can take this advice, or not.
Put in photo's, with your license plate blocked.
Really nice looking Jeep, lets hope the wrong guy, doesn't thinks that also.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Put photo's with your license plate blocked.
Law enforcement aside, why? You drive all day with your plates showing, how is that different from showing it on a forum.
TJJL19
TJ
Wider audience! Do you drive into area's where there have been carjacking's, or do you avoid them?
rickinAZ
Phoenix
Most of the guys on this forum drive around more heavily armed than you do. :)
Rob97RR
Rob
Northern 'burbs' Chicago, IL
22 392 XR Rubi, 2023 C8 Corvette Z06 & 2023 Ducati
Stay at home dad to 2 munchkins, best job in the world!
That actually does accomplish something? I always do that out of habit, and every time I wonder if I'm just being paranoid. 😄
Rob97RR
Rob
Are you using anything to increase the width of your setup other than the spacers for your wheels? I really like the width of yours in these pics. They seem farther outward than I would have thought for just a wheel spacer though. You did say 1.75" spacers in your original post, correct?
I guess the tires are an inch wider as well, maybe that impacts the look of the "width" too. Really looks nice though man.
