Word of Warning When Welding Frame
Sean K.
Sean
AZ
JLUR, TJ, 4Runner, Cummins tow rig, 2 Tube Frame Buggies, Lotus SC Elise, Mazda 3, RAV4 Hybrid
Arrowhead
George
Stillwater, NY
2018 Wrangler JL Sport
Finally, a thread where someone is actually fabbing something! Thanks for the warning.
BosRacing
Bill
Seattle
2018 RAM MegaCab, 2018 Jeep JL, 2020 Jeep Gladiator LE
Cut 6.5" off the front frame rails and am building a winch bumper on the front of the wife's JLUR. While welding some plate to the frame near the core support last night, apparently a molten ball of spatter from the GMAW (Mig) was thrown at the bottom portion of the aluminum radiator and blew a pin hole in it.
I've welded practically on top of several different makes and models' radiators and never had the issue. So, either I just won the lottery on this or the aluminum just isn't as robust as those other vehicles. Regardless, just a warning...the radiator seems to be pretty thin. The molten ball went through a tiny gap that I probably couldn't have prevented even with a welding blanket since I would have had to have moved the blanket to weld the area I was trying to get to. That...or TIG it.
Also, I wonder if the problem with the porous beads we've seen is not from the welding process but from the quality (or lack thereof ) of the base material the frames are made of. It seems to vary when welding. Some sections laid down really nice beads while the ones next to the core support didn't weld worth a darn. All of them were cleaned down to bare metal before welding. I'm suspecting that this is some sort of pot metal or bad alloy mix....at least for ER70S-6.
Portions of the frame are galvanized. Take time and prep well, otherwise your welds will suck.
D60
CO
JL
Found this in search...any special precautions for welding on the JL?
Other than the standard disconnection of the negative batt cable, do I need to worry about the aux batt (3.6 in my case)?
It'd be just my luck to fry the Uconnect...
D60
CO
JL
Ok no problem! I was also going to just disconn the main batt & hope if no replies!
