Most anything.. lights etc, really looking for a good access point. TJ's ,JK's pretty easy access. I can't find a good spot on JL
Thanks, I'll poke around@MIKEY51
Here is one thread that will point you to a firewall grommet on the passenger side...
https://www.jlwranglerforums.com/fo...iring-through-jl-firewall.48434/#post-1072029
and another:
https://www.jlwranglerforums.com/forum/threads/don’t-use-passenger-side-grommet-to-get-wires-through-firewall.41004/
THANKS , I'LL do some poking around@MIKEY51
and another:
Really? Because something else uses it on the manual? Ok, now that I think about it, I guess that makes sense because of where the clutch is. You did specify that you had the 6-speed.Thanks but only on Auto trans
YepReally? Because something else uses it on the manual? Ok, now that I think about it, I guess that makes sense because of where the clutch is. You did specify that you had the 6-speed.
Try this thread: https://www.jlwranglerforums.com/forum/threads/wiring-through-the-firewall.8424/post-838133
