Stingray20Idaho
These?@Ldybug
Your two, 30 watt lights will draw 5 amps or 5,000 milliamps total. You will have no issue at all wiring to the 6 pin. For all the reasons I gave in past posts, saying to avoid the factory tail light harness ,(especially if you JL, has LED light option) DO, tap into the 6 pin and not the tail light harness.
You must use 2 diodes. I would go with the Roadmaster diodes as they hold up well to water, vibration and such.
https://www.etrailer.com/Accessories-and-Parts/Roadmaster/RM-790.html#prod-acc-onlyreviews
