Wiring 6 kc lights to AUX switch
Cutterwolf
Ontario , Canada
2018 Wrangler Rubicon JL, 1963 Ford Fairlane, 2012 Honda Civic EXL
Good morning
I getting confused with regard to installing 6 lights to the AUX switches
I found some 4 light information but none for 6 lights.
The lights are the KC Apollo Pro (MAX 130w each )
Wiring diagram pic enclosed.
On one hand I thought I should use one of the supplied relay per set (2) of lights (so three relays in total) and just connect all the yellow (20amp) fused leads together to the battery and all the grounds together to the ground and all the white load ( 3amp fused) to the AUX Switch...
Now I'm wondering if that's correct.
Or do I just cut off all that stuff and connect all the red light leads connect to 40amp AUX switch and all the black leads to the ground.
I figure each light must be around 9amps each..
So that seems wrong with a 40amp fuse
I'm right in the middle of this at the moment..so any help at all would be great...
Thanks
P.s. I posted this in reply to another thread in stead of starting a new one.. if I broke a rule..my apologies
mortimer
JLUR
Do you want to control the pairs of lights on separate switches?
If so, use three relays, and hook the output of each of 3 aux switches to each of 3 green wires to the relays. You don’t need the a black or white wire from the aux switches as shown in the diagram above.
If not, use three relays, and hook the output of one aux switch to each of the 3 green wires to the relays. Again, you don’t need the black or white wires.
You will need the black and yellow wires from the relays to the battery. The green wires to the relays are triggers and don’t draw the full current of the lamp, so both confines above will be within the current limits of the aux switches.
ETA: can you post a link to the specific lites on KC’s site?
Cutterwolf
Cutterwolf
Ontario , Canada
Hi...first...thanks for the reply...
I'm having trouble getting the exact link...they are the KC #9150 6 inch 100 watt halogen .
I'd like to have them all on one switch AUX #1. I also found this after digging through a bunch of boxes....so the wires to the switch is the confusing part now...I understand what you said about the green to AUX ..but i can just kill all the whites and black....
mortimer
JLUR
That diagram is great. Wire all three relays as shown in the top two relays shown in the diagram.
You don't need the black and white wires shown to the switch shown in the diagram because you won't be using the switch that comes with the light kit, and Aux SW#1 already has it's own power and ground (which are used for the LED on the switch itself.)
BTW, use Brown/Pink stripe for Aux SW#1. I suspect you'll pick up that wire under the hood, and it will go to all three of your green wires into the relays. Also, you can configure the Aux switch through the radio to come on with or without the ignition on.
Cutterwolf
Cutterwolf
Ontario , Canada
That diagram is great. All three relays as shown in the top two relays in the diagram. You don't need the black and white wires shown to the switch because you won't be using the switch that comes with the light kit, and Aux SW#1 already has it's own power and ground (which are used for the LED on the switch itself.
Fantastic....it seemed way harder in my head..lol....
Have a great day....
Back to work...
Thanks again for the help....
mortimer
JLUR
(reading your other thread) I'll also add you shouldn't need any special fuses between the green wires and the Aux switch. The Aux switches are fused, and you'll have fuses on each of your yellow "supply wires" from the battery.
mortimer
JLUR
Back to work...
You're welcome. I made a few minor edits to my previous post to clarify. Let me know if that updated post causes any confusion.
Cutterwolf
Cutterwolf
Ontario , Canada
No..this is great....the only issue I see is that the wife wants me to stop and go shopping for groceries....other than that....I think I should be good...thanks again....
mortimer
JLUR
Happy to help. Let me know how things work out (with the lights ;))
BoundlessBasu
GTA
2017 BMW 330i
Saving this for reference. I always wanted to do KC lights for the windshield like that. What mount bar did you use? And any whistling while driving?
Cutterwolf
Cutterwolf
Ontario , Canada
Its not so bad..the tires are louder..lol
baz
Baz
Montreal, Canada
Rubicon Unlimited 2019
Every time I search the web it doesn't seem like KC has lightbars for JL's, how did you do it? (I'm new to all this so excuse me if this is a dumb question)
Cutterwolf
Cutterwolf
Ontario , Canada
Hey @Cutterwolf , sorry for highjacking the thread a month later but are those 35's with no lift?
Hey ..lol...no problem..no they are 37's with a 2.5 RC budget boost. I got my JL before there were lifts available.
Ill probably swap that out next year, but it works fine for now...
Tazer JL - Z Automotive
