Wires for Aux. switches on Rubicon
quietpeen
Chambersburg, PA
2019 JLUR
I’m posting this here because it’s for wiring up my winch with a power interrupt. I have read that the wires for the Aux switches are under the dash behind the glove box, but i have read something about 4 wires in my bay near the battery(Which I have).
I have a 2019 Rubicon with the 3.6 and auto. Can anybody confirm where the connections for the aux. switches are?
I want to get this wired up this weekend.
JayJay
Johnny
NORTH GEORGIA
'20 JLR
On my '20 model Rubicon the wires were in a bundle pushed down between the battery and the fender liner. Shine a flashlight down there and you'll probably see them.
Later,
Johnny
quietpeen
quietpeen
Chambersburg, PA
2019 JLUR
  • Thread starter
  • Thread Starter
  • #3
Later,
Johnny
I definitely have wires there. Were they labeled which one is which switch on your 2020?
JayJay
Johnny
NORTH GEORGIA
'20 JLR
They're color coded. The code is in the owner's manual under "aux. switches".
JayJay
Johnny
NORTH GEORGIA
'20 JLR
  • Aux Switch 1 F93 – 40 Amp Beige/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
  • Aux Switch 2 F92 – 40 Amp Green/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
  • Aux Switch 3 F103 – 15 Amp Orange/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
  • Aux Switch 4 F108 – 15 Amp Dark Blue/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
This is for the '20 model year. May be the same for yours.
Later,
Johnny
quietpeen
quietpeen
Chambersburg, PA
2019 JLUR
  • Thread starter
  • Thread Starter
  • #7
Later,
Johnny
Wow thanks for the added info. Here is another question that hopefully you or someone else can answer. Should i use a 40 amp aux switch or a 15 am switch for a power interrupt wired up for a 10,000 lb winch?
JayJay
Johnny
NORTH GEORGIA
'20 JLR
One of the 15 Amp. Are you using the Warn Power Interrupt unit? I think the solenoid on it draws 5 amps or less.
Later,
Johnny
Thinman
Rich
CA
2020 JLUR, 2019 Rebel 12 and...... a 2012 Prius
To answer the original question, they are in both locations.
quietpeen
quietpeen
Chambersburg, PA
2019 JLUR
  • Thread starter
  • Thread Starter
  • #11
Really? So there is basically a “Y” in the wiring? Not saying you are wrong just wanting to know. It seems easiest to wire the interrupt completely from the engine bay to me
Thinman
Rich
CA
Yeah, just depends on what you are wiring as to which to use.
Here you go...
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Should be in two place - one up between battery and fender sheet metal. They will be tied/taped up.
The other set under the instrument cluster.
Both are the same, Aux1..Aux4. Combined amp draw for both not to exceed circuit rating (40A or 15A depending on which Aux)
I added one of these, when they were only $20, which was handy.
https://badgeglow.com/product/simpleaux/
limeade
Guy
Reno, NV
2018 JLUR, 2019 JLUR
Use the 15amp switch, save the 40amp ones for other higher draw accessories. I've got my Power Interrupt Kit wired to Aux switch #4 and it's works just fine. I believe @JayJay is correct in that the kit only pulls 5 amps.
Halstem1
Grimes, IA
What would be an example of something needing a higher amp draw? I’m going to install some LED lights. I assume I’d want to keep those on switches 3 or 4 and leave 1 or 2 open for something with more draw.
