Windshield Sprayer Issue
UncommonSense
South Carolina
2018 Wrangler Unlimited JL Sahara
Tried to do a little searching but couldn’t find any relevant threads. My windshield sprayers recently stopped working. I can hear the motor going, and assume there’s a blockage. Is this a known/common issue with the 2018 JLs? And if so, is it something that’s easily fixed or would it be covered at a dealership?
Thanks in advance!
Gee-pah
Andy
SanFrancisco
JL Wrangler
Chris: please know I don't wish to insult.
We have washer fluid correct? And what's the status of fluid on the back window, should you be running a hard top?
UncommonSense
South Carolina
No insult, this occurred shortly after I filled it back up. It hadn’t completely run out, either, so it’s not like I ran it dry or anything.
jludave
The Isle of Long
IT Manager
Should there be an issue, your warranty will cover it. The vehicle is only 2 years old.
Fouts
Marc
Eastern Washington
2023 Rubicon Unlimited
Might take a look at the tubing to see if there is a kink or pinch.
Kluk Ztopolovky
Kluk
Toronto
Wrangler JL Sport 2dr Sting Gray manual
Thanks in advance!
open the hood and often you can see right away where it leaks
UncommonSense
South Carolina
Yup, tried that too, don’t see any leaks. With the wiring running over the top and as crowded as it is around it, I wasn’t inclined to start taking everything apart.
At the dealership now, I’ll give an update.
Kluk Ztopolovky
Kluk
Toronto
good luck , at least the dealership is opened and you can get it fixed
