Boogey
It is winter, it is cold , heater is on most of the time but when the temp regulates or becomes a bit hot i turn off the heat then in about 2 minutes the cabin starts getting cold and i never thought of it ,blamed it on the Cold weather then i noticed a wind / air draft coming from the bottom corner of the front dash where the speakers are , mimic feels like the AC is on flowing just from that place.
It is very noticeable. I checked the corners and there is a slight hole / gap just at the outer edges of the speakers where they meet the pillars on the sides and the windshield at the front.That triangular area when driving feels like a constant stream of airflow coming out!
Is this normal?? I get this is a car that you can take apart and has 100's of seals etc but it feels like a significant amount of airstream to be normal that the cabin gets cold in a matter of minutes.Just under where the VIN small plate is.
I assume in summer its gonna be the same blowing in whatever air the outside is.
There are two small finger sized gaps between the speakers and the pillars where i stuck my finger in but it looked like empty space and seemed like i can pop out the speaker grill if i pulled hard enough.
Should there be some sort of foam or seal under there?
Any help would be appreciated before i have to take this to the dealer.
