Wabujitsu
- Jeff
- Jul 26, 2019
- Sarasota, FL
- 2021 JLUR, 2020 JLU Sahara
- Build Thread
- Link
- Occupation
- Retired US Army
- Vehicle Showcase
- 1
This should work for any winch. I have a Badland ZXR 12000 pound winch. I decided to replace the steel cable with synthetic - 20,000+-rated, half inch in diameter - WAY over-rated for capacity of this winch.
I easily removed all of the bars above the winch spindle, so there are no capacity limitations. I took the solenoid box from the mount on the winch and mounted it on the bully bar. This eliminated the restrictions to winch capacity. I simply opened up the solenoid box, drilled through it into the bully bar, and mounted it with larger diameter sheet metal screws. It is solid. I moisture-sealed all entries into the solenoid box.
I was able to increase winch line capacity dramatically. This should work for all winches. With too much SoCo in my veins, anyone should be able to do this
